cannot get Category Slider to work, please help!
(@zoldos)
I have several categories, each with sub-categories.  I installed Category Slider on WP 4.6.1 with Woocommerce but it doesn't "work".  I checked Widgets etc. and  saw the settings for the plugin, but I don't see any way to "enable" it on my store. Please help!!
(@zoldos)
Wait, it seems I need to "insert" the slider code into my store page.  Correct? It appears to be working now.  Is there a way to make the category boxes smaller? Thanks!
Yes you should use shortcode and put it in some page content. Also WooCS can automatically load a slider with all child categories on parent category page.
I'm sorry but there is no option to manage sizes.
(@zoldos)
Okay thanks!  I ended up using something else which more fit my template. But I appreciate the reply. 🙂
