After deactivating wpDiscuz, Avatars stop showing on comments
 Abv
(@abv)
Before I installed wpDiscuz, all our comments had avatars showing, and now while it's active they show, but when I disable wpDiscuz it breaks the Avatars and they don't show.
wpDiscuz isn't the right solution for us so we'd like to deactivate it. How can I fix this? I've tried seeing if they're turned on in WP settings but they are.
(@varos)
Estimable Member
Hi Abv,
Please note: wpDiscuz does not change any IDs, data etc. We just use the same WordPress functions. Also, maybe before installing wpDiscuz you do not have any avatars. Once you activate it brings them, as we have integration with social logins too.  And deactivate they have gone.
 Abv
(@abv)
That's weird because I know I had avatars before for sure..? Avatars work when I activate wpDiscuz like they used to while still using the old comment system. When I deactivate it they disappear. Note when I activate it it's still the old comments tab I'm looking at, not wpDiscuz, so I know I had avatars before
(@varos)
Estimable Member
Hi Abv,
We have added a few options. Please update it.
