Conflict with theme
Conflict with theme
(@marilyn1998)
Topic starter   [#1915]
my theme, Foodie Pro version 3.0 has a registered. Widget area called After Post. I have three items in it. With the WPdiscuz activated these do not show up. With your plugin deactivated they all appear as expected.
see attached screenshots
5F38A70B D358 4258 A0F2 2736872640B6
367409FC 48A4 44FC A0B9 1F4337794E69
thank you.
(@marilyn1998)
Can you verify your current PHP compatibility? I am using version 7.1
thx
Could You please leave some URL to an example.
(@marilyn1998)
Here is a url.  https://www.marilynstreats.com/amish-pasta-salad/
My mailchimp form is included in post bottom and should show between previous/last post and the comment area.
Did you put it as shortcode? What plugin you use for displaying mailchimp subscription form?
(@marilyn1998)
0F1D8A19 D374 4CFA A19C 28AA97DC1B67
20BBBA57 DDD0 4F1A 97CC 81C072F9376D
C5AABE01 09B7 4025 895C 9C96F2D7C520
Thank you. I am using three different widgets. I have tested with all combinations of these. Nothing shows, where as without WPdusciz anything shows there.
Here are three scrennshots of the widgets dropdown so you can see them. I am using a Custom HTML Widget, Image Widget, and my MailChimp Plugin Widget. I am also including a screenshot of the installed plugin info, Mailchimp for Wordpress version 4.1.14 by ibericode. PHP version is 7 and WP version 4.9.2 and Genesis 2.5.3
