Emojis missing in d...
[Solved] Emojis missing in drop down menue
 thd
(@thd)
[#6055]
emojibug
As shown in the graphic, the emojis of the emoticons add on are not shown in the drop down menue. However when I click on them, they are correctly insertet in the comments text. How can I fix this?
Posted : 25/05/2020 8:41 pm
(@taron)
Hi @thd.
Please update to wpDiscuz Emoticons v7.0.1. The issue should be fixed.
Posted : 25/05/2020 11:23 pm
 thd
(@thd)
@taron That solved the problem. Thank you.
How do I know if a new plugin is available? Do I have to check that manually?
Posted : 26/05/2020 12:21 am
(@taron)
@thd
Did you mean that the new add-on has been published? Or does the existing addon/plugin have a new update?
Posted : 26/05/2020 12:36 am
 thd
(@thd)
@taron new updates on an existing addon
Posted : 26/05/2020 1:17 am
(@taron)
@thd
Basically WordPress checks for new updates every 8-12 hours. But you can do it manually from Dashboard > Updates page, but only do it when you have some problem with the plugin and need to check for updates.
Posted : 26/05/2020 11:28 am
 thd
(@thd)
Ah ok. If the updates are shown up through the normal wordpress update procedure, that will be enough. I wondered wether this would happend or not. Thank you for the info and for your help.
Posted : 26/05/2020 12:33 pm
