Several Issues but all related...
(@jesus-ramos)
[#7249]
Hi, a couple of things: (well maybe some more 🤣 )
It's it possible to add the icon to open the icons with (bottom right corner of text box) up where all the other tools for writing are? *I'm afraid the answer is a "no" and I must admit it's my fault as I discovered later on that you already sort of explaining so somewhere on your website
Also, is there a particular size I can give them to act EXACTLY as the "normal icons" act?. This means, not braking the usual writing as adding any size of the addon icons do as well as keeping themselves aligned in heigh with the text before and after, as well as not altering the text line heigh differences above and below?
Also, perhaps this could be an alternative... is there a way to perhaps use them in a way that can only be used IF used just to give an answer BUT adding no text at all? I mean its there a way that if visitors are going to use an icon they could just do that, use an icon BUT nothing else. Not able to add icon and text together I meant. Otherwise, to be honest, this is not usable for any kind of "serious board" as it breaks all writing out
(I'm not complaining AT ALL because I received what you claimed you deliver, fair enough, but that I'm disappointed, I am)
And lastly, PLEASE can someone explain to me how can I try before I buy next time? Anytime I look into an add-on I see sort of a button to "try it" but I must be too old and/or clumsy because I cant never find a way to try anything at all. All I can do once I get into the place where I'm supposed to "try" is to actually look at what others have done or write themselves
Thanks 🙂
@jesus-ramos,
On each product page, there is a short description and screenshot section. In the case of the wpForo Emoticons Addon you can see it as well. Just go to the Screenshot tab.
Besides each addon has its demo forum on the https://addons.wpforo.com/ community.
On each forum, the first topic created by Martin represents the short description of the addon (with screenshots).
Example: https://addons.wpforo.com/community/postid/1124/
Please try to explain using some screenshots what you need to change. Probably there is some easy way we can help you with.
(@jesus-ramos)
Thanks, I appreciated because of my language limitations Im quite hard to be understood 🙂
For example, using just the screanshot you supply above...
I can see that you have added some icons to the text (as shown in your screamshot) but yet so, your two lines of text seems nicely writted, properly aligned, etc etc
If I write two lines of text and I include ANY of the icons on the add-on pack, regardless of the size I select them to be in the addons config page, the "brake up my text alignment", making the text very "not nice" to be read in a sort of "formal debate forum"
I will activate the addon, put some text, and will add here a screamshot for you to see what I mean
Thanks 🙂
Posted by: @jesus-ramos
Please leave a screenshot of the issue and some example URL where we can see the issue. I think this is just a CSS conflict with the theme or other plugins.
(@jesus-ramos)
Thanks 🙂
Im letting you the url but in anycase I do realise its nothing wrong with your plugin neither a conflict or anything like it. Only that in any case its not usable (its not for me anyway) as "by logic" because of their size they brake all "evenness" between the lines of any single paragraph and I personally do not like it. Perhaps in a children website would be a nice addition 🙂
In any case two more things:
- After I activated the plugin (I didnt noticed this last time I tried), if you use the WRITING SMILE typing in your keyboard "two dots and braket, like this 🙂 - then, EVERY single previous-installation "writing smile" on that page (not juts on that post but in the whole page and I dont know if in other pages too) gets converted into the addon default smile and by its size brakes all previous paragraphs evenness. Are you aware of this?
- Not that would be much good as such at size, BUT, is there any size you know that will be able to add the icons at, in a way that will not disturb in anyway the evenness of the paragraph like happens when you add a "normal non addon smile"?
Thanks 🙂
https://mundopiano.es/foro-de-piano/sugerencias/que-nombre-de-nivel-tras-rompeteclas/#post-87
