[Solved] Make emoticons plugin work in the wpforo recent posts widget?
(@flaren)
[#6391]
I noticed the emoticons don't show up in the wpforo recent posts widget. Can you make an update the plugin so it does work?
Hi @flaren,
I'm sorry, but the content in widgets are stripped. It only contains text information, there is no HTML in that text so there is no way to show emoticons in widgets.
(@flaren)
@tomson ok no problem, thanks for the explaination.
