Hooking into Formidable Forms
(@vectec)
Hi
I want to use Formidable forms to create a post.  I then want to hook the process into the cross posting plugin so when that post is created via Formidable it then creates a cross post on the forum.
Is this possible and what's the best way of doing it?
Hi @vectec,
I'm sorry but we're not familiar with  Formidable forms.
(@vectec)
Ok, well here is the link to their plugin.  It's like Gravity Forms
https://formidableforms.com/
The way it works is you create a form and you can use that form to create a WordPress post when the form is submitted.
Is there any way for me to hook into the process so that once I submit my form it then causes your plugin to fire?
Any ideas or things I can try?
Hi @vectec,
I'm sorry, but we can not guarantee it, as we are not familiar with this plugin. If the plugin works based on WordPress standard functions and hooks it should work fine.
(@vectec)
Let me phrase my question a different way.  If I have the postID and the forumID can I trigger your function programatically without having to manually go into the post edit screen to set it all up?
