[Solved] Close button X not appearing on Attach window
2 Reactions
radiostv
(@radiostv)
[#2320]
As above I've noticed the close attachment window  'X' link which should normally be visible in the top righthand corner, is not visible for me. However when I hover the mouse over where it should be, the mouse detects the link and I can click to close the attachment window just fine.
See attached, any ideas on how to get it back?
I see its ok on your site so it must be something to do with mine but I've no idea how to fix it. Any help would be gratefully accepted.
Many Thanks
attach
radiostv
(@radiostv)
The above example was using Edge, below using Chrome
chrm
and then Firefox
fox
These two show something trying to be rendered whereas Edge as you can see from the 1st post, gives nothing.
Hi @radiostv,
It seems there is a CSS conflict with your theme.  We cannot be registered on your website.  Please register the new user and send it privately(PM) or to support[at]gvectors.com email address.
screen
radiostv
(@radiostv)
That's odd because a person called sofy from Gvectors registered OK this morning but never came back to set the password. Try registering now, I've disabled Geo blocking.
pm sent
Thank you @radiostv,
Sofy is our support member.
Please navigate to Dashboard > Forums > Settings > Styles admin page, put this CSS in "Custom CSS Code".  Save it, delete all caches and do Ctrl+F5 on front-end.
.fa-window-close:before{
content"\f410" !important;
