[Solved] "Add to post" not translated
(@trunky)
[#5338]
In the heading one can translate the "add to post" but in the 2.x new window it seems not able to get translated?
grafik
Thank you for letting us know @trunky,
We're going to check the problem. Please wait a bit. I'll update the topic asap.
This issue will be fixed in the next update.
If you need to solve it asap, please follow the steps below:
1. Open the wpforoattach.php file in the wp-content/plugins/wpforo-advanced-attachments/ folder
2. Find the following line:
'my media' => __('My Media', 'wpforo_attach'),
3. insert this line right after it:
'add to post' => __('add to post', 'wpforo_attach'),
4. Then navigate to Dashboard > Forums > Settings > Addons > attachments subtab
5. Find and change the value of the newly added "add to post" phrase
(@ajay-soni)
The image attached is not showing in recent posts or in the forum. That's why I purchase this plugin: WP Advance
@ajay-soni,
Please open a separate support topic and describe more in details the issue you've faced.
(@trunky)
thank you for the fix!
