[Solved] wpForo Ads Manager does not work unfortunately
(@vshamraeva)
[#1884]
Hi
After installation and activation I tried to create an add.
it doesnt matter what I do, what content I try to add (media, text etc.) I get always a "Ad adding error".
In the Demo the version 1.2.0 is mentioned... I have in "Available downloads" the version
Kind regards,
Victoria
(@vshamraeva)
I tried to create an "ad", of couse, not an "add"..
Hi Victoria,
Please make sure you use the latest wpForo and wpForo Ads Manager addon versions only.
Also please make sure the wp_wpforo_ads table exists in database. Use Hosting Service cPanel > phpMyAdmin database manager tool. If this table doesn't exist, please execute this SQL:
SET SQL_MODE = "NO_AUTO_VALUE_ON_ZERO";
CREATE TABLE `wp_wpforo_ads` (
`adid` bigint(20) UNSIGNED NOT NULL,
`title` varchar(255) COLLATE utf8mb4_unicode_ci DEFAULT NULL,
`code` text COLLATE utf8mb4_unicode_ci,
`body` longtext COLLATE utf8mb4_unicode_ci,
`start_date` datetime DEFAULT '0000-00-00 00:00:00',
`end_date` datetime DEFAULT '0000-00-00 00:00:00',
`forumids` longtext COLLATE utf8mb4_unicode_ci,
`hide_for_groupids` longtext NOT NULL DEFAULT '',
`tpllocs` varchar(255) COLLATE utf8mb4_unicode_ci DEFAULT NULL,
`status` tinyint(1) UNSIGNED NOT NULL DEFAULT '1'
) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci;
ALTER TABLE `wp_wpforo_ads`
ADD PRIMARY KEY (`adid`),
ADD KEY `start_date` (`start_date`),
ADD KEY `end_date` (`end_date`),
ADD KEY `tpllocs` (`tpllocs`(191)),
ADD KEY `status` (`status`);
MODIFY `adid` bigint(20) UNSIGNED NOT NULL AUTO_INCREMENT;
If your database table prefix is not wp_ please change it.
 ikir
(@ikir)
Worked for me!
(@tracy-craig)
I can not get the ads manger to work in wpforo. I create an ad and then go look for it and its not there. Can anyone help?
