How to edit color of widget title structure?
(@myrouble)
[#2318]
Hi! I bought addons wpDiscuz Widgets. How to edit color of widget title structure? Now my title is transparent and I can't see it.
95132 clip 109kb
69e18 clip 119kb
Hi @myrouble,
This is a conflict with your theme CSS style. Please put this CSS code in your theme Custom CSS code section or in style.css file. Save it delete all caches and do Ctrl+F5 on website front-end:
.wpdiscuz-widgets-content h3.widgettitle{color:#333333 !important;}
The #333333 is a color code (dark grey) you can change it to whatever you want.
https://www.w3schools.com/colors/colors_picker.asp
(@myrouble)
Posted by: Tom
Hi @myrouble,
I solved this problem with the help of this style:
#widget-comments-container .widget-title{color: #4A4A4A}
Clip2net 180506105556
My site https://myrouble.ru
(@myrouble)
And how do I change the color of links as well as comments
Clip2net 180506105221
These are not a simple text, these are links so they have link color. Use this code to change the text and link color in widgets:
.wpdiscuz-widget-comment-content .wpdiscuz-widget-comment-exc,
.wpdiscuz-widget-comment-content .wpdiscuz-widget-comment-exc a {color:#333333 !important;}
