[Solved] does not work on gmail in Message to mentioned user
(@jackman12)
The line setting </br> does not work on my Gmail email, it works on another provider.
I don't understand, because it works well when I receive an email from WPdiscuz (when I'm mentioned here on the support forum).
Thanks for your help.
Hi @jackman12,
Please try to remove the slash symbol in the tag, i.e. use the following tag <br>
(@jackman12)
It worked! You're very smart, thank you.
