[Solved] unable to submit comment whiling filling the name field with "anonymous"
 itlr
(@itlr)
Topic starter   [#3748]
Testing the plugin, I have removed the flood filtering with the following code:
add_filter('comment_flood_filter', '__return_false');
I'm not making the name and email fields required. I intend to let users to submit comments without filling them. But the form auto-fills the name field as "anonymous" and next time I open the browser and submit a form, I have to clear the name field in order to submit the comment. I am not sure if it's the flood filtering still taking effect or something else.
 itlr
(@itlr)
微信图片 20190404085925
The error says "Please make sure it's consistent with requested format"
 itlr
(@itlr)
actually it's “Please match the requested format”, doesn't the name field support Chinese characters? If not How do I turn off customize the validator?
Thanks.
 itlr
(@itlr)
Found the cause, I set guest name to have a restriction of at least 3 chars.
Thank you for letting us know. Glad to hear that the issue is solved.
