Ultimate member integration not working
(@davipar)
Before the UM update you could click the user's avatar on a comment and go to their profiles. But now it doesn't work. i've tryed to delete and pasting again the integration code but is not working anymore...
Could you help me? Is really important
(@davipar)
By um i mean ultimamte member integration code that you include with the plug in
Hi  davipar,
I'm sorry but we can't keep updating UM integration code with each UM updates. We'll look at this issue after wpDiscuz 4.0.0 release. This will take lots of time to check all new functions of UM and try to adapt wpDiscuz with UM. I'm really sorry but currently we're working hard on wpDiscuz major 4.0.0 release. We'll get back to this issue next month.
(@davipar)
It's ok, thanks for the answer and good luck on the 4.0.0 release!
