[Solved] Thumbs up and Thumbs down not showing.
 Alex
(@alex)
Hi there,
check this image here:
The thumbs up and thumbs down buttons are not showing. I tried to disable all the plugins, changed to the default wordpress theme with no success.
Im running on the latest wordpress version 4.6.1
check it out live on my website:  http://goo.gl/er6w4u
(@varos)
Estimable Member
Hi Alex,
In the settings, options style tab, scroll down, and you will see "font awesome", please "uncheck" it and save.
Alex576 reacted
 Alex
(@alex)
 Thank you. This solved the issue.
(@varos)
Estimable Member
Ok Alex,
Thanks for letting me know. Good luck!
