[Solved] no post button?
5 Users
22 K Views
 Tim
(@movemenstudios)
Im using WPDiscuz but when i try to post something there is no button to post my comment? Where is this button or how do i enable it?
Voorbeeld
(@varos)
Estimable Member
Hi Tim,
It seems you have js error.
 Tim
(@movemenstudios)
So how do i fix this js error?
Could you please leave some URL?
(@floriankpunkt)
Hi, i have the same problem. There is no submit button to post comments. Example:  http://www.dealn.eu/kostenloses/ueber-1-million-ebooks-2738-kostenlose-buecher-lesen-mit-aldi-life-ebooks/
(@floriankpunkt)
There are no fields for name and email too, i just see. Settings are checked. Is there a fix? Hope you can help me.
(@varos)
Estimable Member
Hi floriankpunkt,
I do not see wpDiscuz, please activate it. I need to check.
(@floriankpunkt)
Hi VaroS, i just activated wpDiscuz. It seems there is a problem with the hueman theme in single.php, line <?php if ( hu_is_checked('post-comments') ) { comments_template('/comments.php',true); } ?>.
(@floriankpunkt)
I have found the problem. There was a problem with the voter plugin. I deactivate it, now it seems it is all ok.
(@golfplan18gmail-com)
The button to post comments does not appear. When I disable the plugin, the button does appear. The post is set to allow comments.
Capture
Please navigate to Dashboard > Comments > Forms admin page, edit the Default Form and make sure the Submit button exists then save it, delete all caches and do Ctrl+F5 on front-end.
That did not work.
For whatever reason, I have 16 copies of the default form. I edited the most recent one. I checked a box that was outlined in red that said "The red marked post types are already attached to other comment form. If you set this form too, the old forms will not be used for them."
Untitled 1
After making the change, the comment subscription box appeared, but no button.
Also, the comment search doesn't work.
Untitled 2
Could you please send admin login details to support[at]gvectors.com email address? it seems you're configuring thing incorrect. We'll login and check all within next 24 hours.
Also please explain what means exactly "the comment search doesn't work.".
I have the comment search add-on, and when I type something in the box, nothing happens. The three-line hamburger changes the cursor to a hand, but when I press it nothing happens. It doesn't begin the search and display any results as I type. Basically, it does nothing.
http://ochousingnews.com/benefits-homeownership-subsidies-fail-justify-costs/#comments
Please note, all problems comes from pb-add-on-social-connect plugin. We don't know what plugin is this but it generates lots of JS errors which affects wpDiscuz. please remove this plugin , delete cache and then test wpDiscuz.
2017 05 02 0117
I disabled that plugin. The plugin allows members to sign on to the site using their social media accounts. I don't know why that would even come up on a post. I disabled it and cleared my cache, but I still don't see a post comment button.
My web host sent me this message "Tell them that I disabled xmlrpc.php ... This is a known hack point... "
This issue is solved, please check it.
It's working now. Thank you.
