My Avatar Doesnt Display
(@bformhals)
Ok, Before installing the comment system plugin (which does seem pretty good) my Avatar as an Author and Admin always displayed. Now all that shows is my information.
It should not get rid of my image I wouldnt think? Is there a setting causing this or does it just eliminate it?
It depends on the avatar plugin you use. wpDiscuz is designed for default avatar system and for some profile plugins ( BuddyPress, Ultimate Member, UsersUltra). Also wpDiscuz supports WP First Letter plugin avatars, other 3rd party avatars are not supported.
