Search
Close
AI Search
Classic Search
 Search Phrase:
 Search Type:
Advanced search options
 Search in Forums:
 Search in date period:
 Sort Search Results by:
Login Widget - not appearing
(@technicalproducts)
  [#7742]
I just installed wpDiscuz Frontend Moderation.  I have the login widget on my site and it's showing up.  I stopped front end cache and it still does not fix the issue.  It will randomly appear and then stop working again.
I tested this issue in the most recent browsers Chrome and firexfox with the same result on PC and mobile.  I had several site users notify me of the same thing.
What is a login solution that I can use if the login widget doesn't show up?
login
Topic Tags
@technicalproducts,
The login Widget you're using doesn't have any relation to the wpDiscuz plugin. You should contact the corresponding plugin support with this question.
