How do I hide comment subscription bar?
(@pinkgecko)
According to the support documentation, I should be able to disable the comment subscription bar. However my settings don't appear to correlate to the support docs so I can't work out how to do it. Can you help?
1. To disable subscription bar
subscription bar
Please navigate to Dashboard > Comments > Forms admin page. Then edit the Default Form, just disable subscription bar option.
2. To disable subscription confirmation
notify
Please navigate to Dashboard > Comments > Settings >  Subscription admin page. Disable  "Notify of new replies to this comment" option.
notify disable
(@pinkgecko)
Thank you. I looked all over but didn't see it there!
Thanks again. 🙂
