Get Comments from Particular Post
(@cwhlin)
Topic starter   [#2654]
Hi. I'd like to get the comments for a particular post to show up on another page (while retaining all the WPDiscuz format and functions).  Any quick and easy way to do that (other than using an iframe)?
(@lidstrom)
Hi! I'm trying to do the same thing.
I tried this code:
$args = array(
'p' => 868 // works on my server; use whatever ID you need
$qry = new WP_Query($args);
if ($qry->have_posts()) {
while ($qry->have_posts()) {
$qry->the_post();
comments_template();
It works but it shows the comments with the default style from WP. The plugin doesn't work.
Do you know why?
Thanks!
(@lidstrom)
It works now with that code.
Dear @cwhlin, @lidstrom,
I'm really sorry but it's not possible. You'll have a lot of conflicts. wpDiscuz is not designed to work this way.
