Forced Page Refresh After Submitting a Comment
5 Users
 Wern
(@wern)
After Posting a commend, the loading shows, followed by some pink line, and then nothing.  The text and Image stays in the "Join the Discussion" box until a page refresh is done after which the Comment shows where it should. How can I fix this?
Hi Wern,
Could you please leave your website URL to allow us to check it?
(@nhammer)
Was a solution found for this? I am having the same issue.
(@romulittle)
@nhammer
Me too
Hi @nhammer, @romulittle,
This kind of issue is usually caused by either conflict with other plugins or the active theme.
Please deactivate the plugins one by one and check after each deactivation to find the problem maker one.
Don't forget to press Ctrl+F5(twice) on frontend each time before checking.
(@2fanatyk2)
Was the solution to this one found? Which plugin is conflicting?
Best regards,
Adam
