Error message question
(@weninrome)
Topic starter   [#3354]
Hello
My server host has recently informed me of the following issue:
mysql> SELECT COUNT() FROM wp_comments WHERE ( comment_approved = '1' ) AND comment_type != 'private' ORDER BY wp_comments.comment_date_gmt DESC ;
| COUNT(
| 486669 |
1 row in set (3.63 sec)
Effectively the comment system is continuously trying to calculate the total COUNT of all non-private comments, which takes several seconds per query.
Can you please let me know which of the WpDiscuz features would be causing this?
This SQl query need to generating comment threads for website visitors. The problem is in your table structure, not in the query. As far as I see your wp_comments table don't have appropriate indexes so it takes so long time. Please open phpMyAdmin Database manager of your hosting service > cPanel, navigate to WordPress database, press on SQL Tab and execute this query. It'll create some important table indexes to make this query very fast:
ALTER TABLE `wp_comments` ADD INDEX( `comment_approved`, `comment_type`);
ALTER TABLE `wp_comments` ADD INDEX( `comment_post_ID`, `comment_approved`);
ALTER TABLE `wp_comments` ADD INDEX( `comment_post_ID`, `comment_approved`, `comment_type`);
2019 01 06 1230
It may take a while, so you can execute them one by one with three times.
(@weninrome)
Thank you i have asked my server hosts to enter this code.
(@weninrome)
Hello
Please see the note from my server hosts. How can I respond?
We've tried to implement various indexes including the ones supplied by the developer, but unfortunately the indexes can not be added:
mysql> ALTER TABLE wp_comments ADD INDEX( comment_approved, comment_type);
ERROR 1067 (42000): Invalid default value for 'comment_date'
mysql> ALTER TABLE wp_comments ADD INDEX( comment_post_ID, comment_approved);
mysql> ALTER TABLE wp_comments ADD INDEX( comment_post_ID, comment_approved, comment_type);
This is because the "comment_date" field is type "datetime", which according to the MySQL docs is limited to the range '1000-01-01 00:00:00' to '9999-12-31 23:59:59' (refer to  https://dev.mysql.com/doc/refman/5.7/en/datetime.html ). The default value for the comment_date field is "0000-00-00 00:00:00" which is outside this range.
We could try altering the table to fix this default value; please check with your developer if this would be OK.
Hi @weninrome,
You should add this line before those SQLs.
SET SQL_MODE = "NO_AUTO_VALUE_ON_ZERO";
They should be executed together, like this:
