Comments not showing
(@diegothx)
Hi, I'm new here.
I installed wpDiscuz 2 days ago, and also bought the Media Uploader plugin. All seems to work properly until I noticed that the comments itself doesn't show.
If a user comment, and reload the site, the comments aren't shown in the comments section. Also, it always shows the same comment, in all the posts.
For example, this 2 posts have different comments in the WP-admin, but in the front I can't see the comments:
http://sintropiadesign.com/sitios/test/final_rizoma/carpe/
http://sintropiadesign.com/sitios/test/final_rizoma/croma-material-didactico/
I'm trying everything but I don't know what to do.
(@diegothx)
Here you can see the comments in the WP-ADMIN section:
(@varos)
Estimable Member
Hi Diego,
First of all, deactivate all plugins which you have, leave only wpDiscuz. Try to post a comment and check the result. If does not help, try to deactivate your current template, use WordPress default theme and again, try to post a comment. In this case, please try with all plugins activated and deactivated in the default theme. We think the issue comes from template.
