Comment Subscription - Option not to Subscribe?
(@phantek)
Is it possible to add an option to the Comment Subscription drop-down, giving the user the ability not to subscribe to any follow-up comments or replies?
It allows you to subscribe to any follow up comments, but only for this post. wpDiscuz is not a subscription plugin and it doesn't have general subscription functions. It's only designed for comment box, which is post specific area.
(@kyliec1)
Hi there, I have a similar question - is it possible to turn off the option of displaying anything related to email subscriptions? In the customisation fields on the 'subscription' tab in 'settings', there is no option to hide this completely? I don't want to show that field on my form...
Posted by: kyliec1
Hi kyliec1,
I don't think this is the same issue. There is an option in comment form settings to disable comment subscription bar. You should know that wpDiscuz has comment form customization feature, this is the main important feature of this plugin. Just navigate to Dashboard > Comments > Forms admin page, edit the Default Form and disable subscription bar.
(@kyliec1)
Excellent, thanks, I completely missed that! Now it's nearly perfectly exactly how I want that area to look, great plugin!!
