Comment keeps on loading.
(@ibarts)
Topic starter   [#490]
When any guest comments, comment does not load untill page is refreshed. While if registered user comments "wpdiscuz-comment-message wc_invalid_field" box is displayed check here  http://dh.nixymedia.com/2016/05/29/wpdisquz/
Please help
Hi ibarts,
something affects wpDiscuz comment submitting process. please deactivate all plugins, delete cache and test it again. If it doesn't you should test it with default WordPress theme. Unfortunately it's not possible to debug this issue on front-end, you should do the steps I just explained to find the conflict point.
