[Solved] Change limit for comment edition (from 15 to 5 minutes)
(@dooomer)
Topic starter   [#4682]
Hello, is there any way/hack to change default time limit for comment editing? 15 minutes is more than enought, so I would like to set it to 5 minutes for example 🙂
Hi @dooomer,
Please follow the steps below:
1. Open the settings-form.php file  in the /wp-content/plugins/wpdiscuz/options/options-layout/ folder.
2. Find the following line  (line 183)
<option value="900" <?php selected($wc_comment_editable_time, '900'); ?>>15 <?php _e('Minutes', 'wpdiscuz'); ?></option>
3. Replace with this one:
<option value="300" <?php selected($wc_comment_editable_time, '300'); ?>>5 <?php _e('Minutes', 'wpdiscuz'); ?></option>
Important: the changes will be lost after wpdiscuz update. You should keep somewhere locally the code.
We will also take into consideration to add the 5-minute limitation for the "Allow comment editing for" option.
(@dooomer)
Dear Elvina,
thank you for your amazing support. I will save these code changes, but it will be cool if you can add 5 minutes option to the settings for future updates 🙂
