[Solved] Active/new users
 Rjk
(@rjk)
Estimable Member
Is it somehow possible to see the active users and or the new users?
Hi @rjk,
The wpDiscuz doesn't have such a feature.
However, we may suggest you check out the wpDiscuz Widget add-on. The addon has a "MOST ACTIVE COMMENTERS" tab, where is display the active commenters(users). More info here: https://gvectors.com/product/wpdiscuz-widgets/
Posted by: @rjk
......new users?
I'm sorry but there is no way to see the new users.
 Rjk
(@rjk)
Estimable Member
Many thanks for the reply. I do own the Widget, already tested with that.
Regards,
