Forum areas can not...
Forum areas can not be properly Sotieren.
(@paxrisen)
Topic starter   [#1522]
I have more and more the problem that forum areas no longer synonymous Sotieren leave or a complete forum area itself. Will there be a new version to solve the solangsam the problem solved or a new function for the Sotieren? The I would reluctantly use my web host server Manuel the numbers enter the that takes just a long time with so many forum areas I must still paste.
Here is an area that has itself currently confused the order:
http://gamesummary.de/forum/achievement-trophaeen-sony-playstation-4/
I'm sorry but I can't follow you. What do you mean saying "forum areas"? And what is the problem, please show on screenshots and try to explain it again.
(@paxrisen)
I mean the only forums I created. At
the moment in the Playstation 4
is the problem with each new forums itself the order automatically
changed and not sotiert after the alphabet. The annoying is that when
I sotiert it is usually not taken over or with the next forums again
everything is messed up
It seems you don't click on this button after setting the hierarchy. Please make sure you've saved hierarchy in Dashboard > Forums > Forums admin page.
wpForo Save Forum Hirachy
(@paxrisen)
The button I always use after I have the forums sorted. Unfortunately, this button has no function anymore since I have created over 380 forums.
Ok, yu should increase these values of your Hosting Service PHP configuration. Ask hosting service support:
PHP Limits (recommended)
  • post_max_size = 128M
  • max_input_vars = 10000
It's already described in wpForo Documentation - Server Requirements:
https://wpforo.com/docs/root/wpforo-installation/server-requirements/
