Add topic option is...
Add topic option is not work
(@hadeat)
Topic starter   [#2512]
MY forum is  http://eujourney.com/community. Add topic option is not work. How can I fixed it.
You have lots of JS errors on websites. They affects wpForo functions. Please fix these errors. you should disable all plugins and change the theme, then revert those back one by one and find the problem maker.
2018 06 10 2310
This problem cannot be fixed from wpForo side, you should find the problem maker to fix it.
