Pagination results contain Visual Composer shortcodes
(@gem1)
Topic starter   [#530]
Hi there,
I purchased the Avanced Content Pagination pro plugin as I need to add pagination to particular pages for a website using Visual Composer. I am using the <!--nextpage--> shortcode which makes the pagination display, however when I click on the next button or number 2 etc the results show a bunch of Visual Composer short codes.
VC shortcodes pagination
How do I strip the VC shortcodes out of the results? Is there something I need to add to functions.php? I had a similar issue with Relevanssi (for search results) and had to add code to functions.php to fix it.
Your help with this is very much appreciated.
Thanks.
Gem
There are lots of thing on your case which may affect and conflict with ACP Pro. We can't help you without direct access to all this. Please send admin login details to support[at]gvectors.com email address. We'll login and check these issues.
