ACP Tab does not work in mobile browser
(@aballoonflies)
Topic starter   [#59]
While ACP tab works wonderfully in desktop, the mobile version is less to be desired.
I have 4 tabs with title. On mobile it shows two tabs and requires tapping on next arrow to see the third one, which is fine. But when I tab, it would load the nonexistent page of the blog. URL being http://[site url]/[blog]/undefined
Anyway I can sort this out?
Hi aballoonflies,
Please leave some example URL to a page with ACP buttons. What ACP version you use?
(@aballoonflies)
you can see  http://blog.specapp.cc/photo-courtneys-1m3-clone/
Unfortunately I cannot use the tab ACP on live blog..currently its using default pagination.
v1.1.2 on wp 4.1 it is.
(@thisisrammy)
I also have this problem, here are two examples URL's that work great in desktop but not so great in mobile.
http://www.thisisrammy.co.uk/8-amazing-facts-about-wind-turbines
http://www.thisisrammy.co.uk/7-facts-about-peel-tower-you-didnt-know/
thanks
(@brookscl)
I've got the same problem. Any chance on making this responsive, or giving other options when mobile rendering?
http://plan-pack-go.com/new-orleans-mardi-gras/
Hi brookscl,
we don't see any issue on your website, all works perfect for us.
IMG 8667
IMG 8666
(@brookscl)
I realize it works to the extent that after an initial touch the navigation buttons appear, but I think the expected behavior should be that if the entire pagination menu is not visible / truncated, then the navigation arrows should appear.
Additionally, when the buttons do appear and you navigate through the option and select a page, it doesn't get the focus highlight unless you then press an arrow button again.
These aren't huge issues - just suggestions for cleaner behavior in the mobile environment.
