GDPR compliance
(@rvencu)
Hi, GDPR compliance requires more than just cookies consent. In case of comments we must be able to allow user to visualize his comments and mark some or all for deletion. Before letting the visitor to leave a comment we need to inform him about GDPR things and ask for consent.
There is a plugin named WP GDPR that already does all of this (perhaps with aids of filters) but it is not working against wp discuzz. I would like to see it well integrated with WP Discuzz. If not possible and if WP Discuzz is not writing it own add on the we must remove it from use and find another solution. I hope you can solve this situation.
Please contact to this plugin developers and ask them to fix the Fatal error. This error is the reason of integration problem. This can't be fixed from wpDiscuz size.
2018 02 13 1612
(@rvencu)
Thanks. I hope they will issue a new version soon taking advantage of your recent hook for GDPR
(@per4mance)
Maybe this is an alternative solution for you all without any plugin except wpDiscuz https://gvectors.com/forum/general-forums/gdpr-checkbox-easy-going-made/
