									Place custom fields above thread content? - wpForo Topic Custom Fields				            </title>
            <link>https://gvectors.com/forum/wpforo-topic-custom-fields/place-custom-fields-above-thread-content/</link>
            <lastBuildDate>Tue, 06 Oct 2026 12:47:46 +0000</lastBuildDate>
                        <title>RE: Place custom fields above thread content?</title>
                        <link>https://gvectors.com/forum/wpforo-topic-custom-fields/place-custom-fields-above-thread-content/#post-41024</link>
                        <pubDate>Mon, 09 Dec 2024 18:49:20 +0000</pubDate>
                        <description><![CDATA[This worked, for the most part.
I ended up having to put it in the theme&#039;s custom CSS instead of the forums, though, to get it to work on Safari. I don&#039;t know what conflict made it necessar...]]></description>
                        <content:encoded><![CDATA[<p>This worked, for the most part.</p>
<p>I ended up having to put it in the theme's custom CSS instead of the forums, though, to get it to work on Safari. I don't know what conflict made it necessary, but at least the alternate location for the CSS worked.</p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/wpforo-topic-custom-fields/">wpForo Topic Custom Fields</category>                        <dc:creator>Kelly Peterson</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-topic-custom-fields/place-custom-fields-above-thread-content/#post-41024</guid>
                        <link>https://gvectors.com/forum/wpforo-topic-custom-fields/place-custom-fields-above-thread-content/#post-41022</link>
                        <pubDate>Mon, 09 Dec 2024 08:52:32 +0000</pubDate>
                        <description><![CDATA[@kelly-peterson 
I&#039;d suggest you use the CSS code below:
#wpforo #wpforo-wrap .wpforo-post .wpf-right .wpforo-post-content {
  display: flex;
  flex-direction: column-reverse;
Insert...]]></description>
                        <content:encoded><![CDATA[<p>@kelly-peterson </p>
<p>I'd suggest you use the CSS code below:</p>
<pre contenteditable="false">#wpforo #wpforo-wrap .wpforo-post .wpf-right .wpforo-post-content {
  display: flex;
}</pre>
<p>Insert the code in the Custom CSS code textarea located in the following tab: </p>
<p>For the Single Board Forum:</p>
<ul>
<li>Dashboard &gt; wpForo &gt; Settings &gt; Colors &amp; Styles</li>
</ul>
<p>Multi-Boards Forum:</p>
<ul>
<li>Dashboard &gt;<span> </span><span> </span>&gt; Settings &gt; Colors &amp; Styles tab</li>
<li>Dashboard &gt;<span>  </span>&gt; Settings &gt; Colors &amp; Styles tab</li>
</ul>
<p>For example:</p>
<ul>
<li>Dashboard &gt;<span> </span><span><strong>EN</strong> </span>Forum &gt; Settings &gt; Colors &amp; Styles tab</li>
<li>Dashboard &gt;<span> </span><span><strong>FR</strong> </span>Forum &gt; Settings &gt; Colors &amp; Styles tab</li>
</ul>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/wpforo-topic-custom-fields/">wpForo Topic Custom Fields</category>                        <dc:creator>Astghik</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-topic-custom-fields/place-custom-fields-above-thread-content/#post-41022</guid>
                        <link>https://gvectors.com/forum/wpforo-topic-custom-fields/place-custom-fields-above-thread-content/#post-41016</link>
                        <pubDate>Sat, 07 Dec 2024 21:20:29 +0000</pubDate>
                        <description><![CDATA[Being more specific, here&#039;s an image of how I would like it to arranged, instead of how it is currently arranged.]]></description>
                        <content:encoded><![CDATA[<p>Being more specific, here's an image of how I would like it to arranged, instead of how it is currently arranged.</p>
7497]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-topic-custom-fields/place-custom-fields-above-thread-content/#post-41016</guid>
                        <link>https://gvectors.com/forum/wpforo-topic-custom-fields/place-custom-fields-above-thread-content/#post-41015</link>
                        <pubDate>Sat, 07 Dec 2024 21:14:31 +0000</pubDate>
                        <description><![CDATA[I just want to move where the fields about the topic are to above that first post instead of below it.]]></description>
                        <content:encoded><![CDATA[<p><a href="https://chosenofstarclan.com/community/postid/56281/" target="_blank" rel="noopener">https://chosenofstarclan.com/community/postid/56281/</a></p>
<p>I just want to move where the fields about the topic are to above that first post instead of below it.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-topic-custom-fields/place-custom-fields-above-thread-content/#post-41015</guid>
                        <link>https://gvectors.com/forum/wpforo-topic-custom-fields/place-custom-fields-above-thread-content/#post-41013</link>
                        <pubDate>Sat, 07 Dec 2024 10:00:42 +0000</pubDate>
                        <description><![CDATA[Hi,
Please provide us with an example URL, and we’ll attempt to offer a CSS solution if possible.]]></description>
                        <content:encoded><![CDATA[<p>Hi,</p>
<p>Please provide us with an example URL, and we’ll attempt to offer a CSS solution if possible.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-topic-custom-fields/place-custom-fields-above-thread-content/#post-41013</guid>
                        <title>Place custom fields above thread content?</title>
                        <link>https://gvectors.com/forum/wpforo-topic-custom-fields/place-custom-fields-above-thread-content/#post-41011</link>
                        <pubDate>Sat, 07 Dec 2024 00:01:08 +0000</pubDate>
                        <description><![CDATA[Is there a way to get the fields users have field out to show before the content of the post they write when creating a topic?]]></description>
                        <content:encoded><![CDATA[<p>Is there a way to get the fields users have field out to show before the content of the post they write when creating a topic?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-topic-custom-fields/place-custom-fields-above-thread-content/#post-41011</guid>
