Translation problem
(@robinbrousse)
I just bought you the plugin wpForo Private Messages.
I correctly filled in the .pot file and then I created a files wpforo_pm-fr_FR.po wpforo_pm-fr_FR.mo
Until then it's nominal ... except that the translation does not work 🙁 And I dont understand why ?
Thank you for your quick reply
Have a nice day
Emmanuel
Hi  @robinbrousse,
Thank you for your purchase.
Please don't create new wpforo_pm-de_DE.po file. You just need to add the phrases in wpforo_fr_FR.po file. As you've already translated the phrases just copy and paste those at the end of wpforo_fr_FR.po file.
Don't forget to delete phrase cache from Dashboard > Forums >  Dashboard admin page.
(@robinbrousse)
Thank you for your reply 🙂
Now it works with the translations of sentences in the admin. On the other hand, there are phrases that do not exist in the .PO and in the phrase manager:
Write PM
Refresh
Load all messages
Turn off email notification
Delete all messages
Succefuly hidden
Something else. Deleting messages is a problem. To fix that, I had to disable WP-Rocket (cache plugin). It's ok, but the plugin it's not at all ergonomic
And i have another problem with WpForo. It's the same there are sentences that are translated in the .PO and the admin but the translation does not work. For example :
---> Currently viewing this topic 1 utilisateur
I have already bought two extensions. Before buying more I would like everything to work normally.
Have a nice day
Emmanuel
(@robinbrousse)
I forgot 🙂 With WpForo Private message, users receive a notification by email. But not the administrator.
Hi @robinbrousse,
If some phrase is missing. Just navigate to Dashboard > Forums > Phrases admin page, click on [Add new] button. Insert phrase key with identical English phrase and the value whatever you want. Save it, delete all caches and check.
This is a known issue, please read this support topic, it gives a temporary solution:
https://wpforo.com/community/how-to-and-troubleshooting-2/line-translation/#post-20162
I'm sorry, but I don't follow you, could you please clarify a bit? If you mean admin should get a message when the user sends a private message to the other users. I'm sorry, but wpForo PM doesn't have an option for this.
