									Where do I set up myCred for wpforo? - wpForo myCRED Integration				            </title>
            <link>https://gvectors.com/forum/wpforo-mycred-integration/where-do-i-set-up-mycred-for-wpforo/</link>
            <lastBuildDate>Mon, 20 Apr 2026 10:17:40 +0000</lastBuildDate>
                        <title>RE: Where do I set up myCred for wpforo?</title>
                        <link>https://gvectors.com/forum/wpforo-mycred-integration/where-do-i-set-up-mycred-for-wpforo/#post-37212</link>
                        <pubDate>Sun, 02 Jul 2023 14:31:10 +0000</pubDate>
                        <description><![CDATA[You should come to the myCRED sections, click on the section Point, then choose Hooks. You will find myCRED wpForo hook there.]]></description>
                        <content:encoded><![CDATA[
<p>I bought and installed the myCRED integration plugin.  However, I cannot find the addon configuration like the PM and Embeds addons.  It does say myCRED integration plugin is installed.  I just don't see anywhere I can turn it on for wpforo. </p>
<p>Is there any kind of documentation on how to enabled and set it up?</p>
<p>I tried to manually assign points to my users in the myCRED config panel but they don't show up anywhere in wpforo. </p>
<p>Please help.  Thanks.]</p>
<p></p>
<p>You should come to the myCRED sections, click on the section Point, then choose Hooks. You will find myCRED wpForo hook there. </p>
<p> </p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/wpforo-mycred-integration/">wpForo myCRED Integration</category>                        <dc:creator>tiengduc.org</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-mycred-integration/where-do-i-set-up-mycred-for-wpforo/#post-37212</guid>
                        <title>Where do I set up myCred for wpforo?</title>
                        <link>https://gvectors.com/forum/wpforo-mycred-integration/where-do-i-set-up-mycred-for-wpforo/#post-37208</link>
                        <pubDate>Sun, 02 Jul 2023 03:24:58 +0000</pubDate>
                        <description><![CDATA[I bought and installed the myCRED integration plugin.  However, I cannot find the addon configuration like the PM and Embeds addons.  It does say myCRED integration plugin is installed.  I j...]]></description>
                        <content:encoded><![CDATA[<p>I bought and installed the myCRED integration plugin.  However, I cannot find the addon configuration like the PM and Embeds addons.  It does say myCRED integration plugin is installed.  I just don't see anywhere I can turn it on for wpforo. </p>
<p>Please help.  Thanks.]</p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/wpforo-mycred-integration/">wpForo myCRED Integration</category>                        <dc:creator>Dazhi Zhang</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-mycred-integration/where-do-i-set-up-mycred-for-wpforo/#post-37208</guid>
