Showing rank title in addition to badge in WpForo
Valinax
(@valinax)
Valinax
Hello, I have created a series of 13 MyCred ranks on my WpForo/MyCred forum, and I have enabled the integration so the rank badges are working fully according to the points of the user. This is good, but I also want to show the names that I have given the ranks next to the badges on both the user’s profiles and above their forum posts. I could do this by resizing the badges with CSS and editing them to include text, but this would be an awkward way and I was wondering if another solution is available? Thanks
You can see these badges here; the grey one should be titled “New” and the animated bright green one should be titled “Valinaxian”:
https://valinax.com/forum/main/valinax-videos-discussion#post-13
(@astghik)
Support Team
Hi @valinax,
I'm sorry, but there is not such a feature. I'm going to ask the add-on developers about this. Probably we'll add it in next version release.
(@astghik)
Support Team
@valinax,
add the following js code in your theme's js files and check again, it'll show the rank title.
jQuery.each(jQuery('.wpforo-mycred-rank-wrap'), function (i, val) {
jQuery('<div/>').addClass('wpforo-mycred-rank-title').html(jQuery(val).children('img').attr('title')).insertBefore(jQuery(val).children('img'));
Valinax
(@valinax)
Valinax
Hi, I appreciate the assistance and that you now plan to add the feature officially. I can't seem to get the code to work if I add it to my functions.php file, am I doing it correctly here?: http://prntscr.com/nlano9
(@astghik)
Support Team
Hi @valinax,
Please remove the code from the functions.php file. This is js code it should be added in js files of the active theme.
Valinax
(@valinax)
Valinax
I've found a way to get it working using a code injection plugin as it was not working when I tried to add it through the theme JS files. Would also be great if it can be individually styled through CSS.
(@astghik)
Support Team
@valinax,
you can add CSS codes in Dashboard > Forums > Settings > Styles > "Custom CSS code" textarea.
Valinax
(@valinax)
Valinax
Meant to say that it would be great if the different ranks could be styled individually through CSS, but I would presume that this would be a significantly more complex feature to add.
