									myCred plugin is not installed! - wpForo myCRED Integration				            </title>
            <link>https://gvectors.com/forum/wpforo-mycred-integration/mycred-plugin-is-not-installed/</link>
            <lastBuildDate>Sun, 08 Nov 2026 02:54:33 +0000</lastBuildDate>
                        <title>RE: myCred plugin is not installed!</title>
                        <link>https://gvectors.com/forum/wpforo-mycred-integration/mycred-plugin-is-not-installed/paged/2/#post-11229</link>
                        <pubDate>Tue, 25 Sep 2018 13:00:39 +0000</pubDate>
                        <description><![CDATA[Or at the very least add the link to your message where you put Mycred not Installed! Put link to click on to show user what you mean...]]></description>
                        <content:encoded><![CDATA[<p>Or at the very least add the link to your message where you put Mycred not Installed! Put link to click on to show user what you mean...</p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/wpforo-mycred-integration/">wpForo myCRED Integration</category>                        <dc:creator>oceanhobby</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-mycred-integration/mycred-plugin-is-not-installed/paged/2/#post-11229</guid>
                        <link>https://gvectors.com/forum/wpforo-mycred-integration/mycred-plugin-is-not-installed/#post-10765</link>
                        <pubDate>Mon, 03 Sep 2018 05:42:12 +0000</pubDate>
                        <description><![CDATA[The purchase of myCRED Integration addon, should say clearly that the myCRED plugin has to be installed first. When I installed 1.7.96.zip, then the 1.0.4.zip the Integration addon worked pr...]]></description>
                        <content:encoded><![CDATA[<p>The purchase of myCRED Integration addon, should say clearly that the myCRED plugin has to be installed first. When I installed 1.7.96.zip, then the 1.0.4.zip the Integration addon worked properly.</p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/wpforo-mycred-integration/">wpForo myCRED Integration</category>                        <dc:creator>wpotter</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-mycred-integration/mycred-plugin-is-not-installed/#post-10765</guid>
                        <link>https://gvectors.com/forum/wpforo-mycred-integration/mycred-plugin-is-not-installed/#post-10683</link>
                        <pubDate>Wed, 29 Aug 2018 07:31:50 +0000</pubDate>
                        <description><![CDATA[Hi @gxsub,Have you installed myCRED pluginthe wpForo  - myCRED Integration addon you should install myCRED plugin before installing wpForo  - myCRED Integration addon. This addon is an integ...]]></description>
                        <content:encoded><![CDATA[<p>Hi @gxsub,</p><p>Have you installed myCRED plugin?</p><p><a class="wpforo-auto-embeded-link" href="https://wordpress.org/plugins/mycred/" target="_blank" rel="nofollow noopener">https://wordpress.org/plugins/mycred/</a></p><p>For the wpForo  - myCRED Integration addon you should install <strong>myCRED </strong>plugin before installing wpForo  - myCRED Integration addon. This addon is an integration solution between <strong>wpForo</strong> and <strong>myCRED</strong>.</p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/wpforo-mycred-integration/">wpForo myCRED Integration</category>                        <dc:creator>Astghik</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-mycred-integration/mycred-plugin-is-not-installed/#post-10683</guid>
                        <link>https://gvectors.com/forum/wpforo-mycred-integration/mycred-plugin-is-not-installed/#post-10680</link>
                        <pubDate>Wed, 29 Aug 2018 04:17:34 +0000</pubDate>
                        <description><![CDATA[Hello I buy MYcred then I activated the plugin and it displays myCred plugin is not installed!Exactly the same like in the last post.You will find creenshots in Attach Files.]]></description>
                        <content:encoded><![CDATA[<p>Hello I buy MYcred then I activated the plugin and it displays myCred plugin is not installed!Exactly the same like in the last post.You will find creenshots in <a id="wpf_attach_button"></a>Attach Files.</p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/wpforo-mycred-integration/">wpForo myCRED Integration</category>                        <dc:creator>gxsub</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-mycred-integration/mycred-plugin-is-not-installed/#post-10680</guid>
                        <link>https://gvectors.com/forum/wpforo-mycred-integration/mycred-plugin-is-not-installed/#post-10344</link>
                        <pubDate>Fri, 10 Aug 2018 06:02:31 +0000</pubDate>
                        <description><![CDATA[Hi kolex59,I&#039;m sorry, but I don&#039;t follow you. Please explain using some screenshots.]]></description>
                        <content:encoded><![CDATA[<p>Hi kolex59,</p><p>I'm sorry, but I don't follow you. Please explain using some screenshots. </p><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-mycred-integration/mycred-plugin-is-not-installed/#post-10344</guid>
                        <title>myCred plugin is not installed!</title>
                        <link>https://gvectors.com/forum/wpforo-mycred-integration/mycred-plugin-is-not-installed/#post-10336</link>
                        <pubDate>Thu, 09 Aug 2018 18:09:51 +0000</pubDate>
                        <description><![CDATA[Hello I buy MYcred then I activated the plugin and it displays myCred plugin is not installed!Thans you help me please]]></description>
                        <content:encoded><![CDATA[<p>Hello I buy MYcred then I activated the plugin and it displays myCred plugin is not installed!</p><p>Thans you help me please</p><p> </p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/wpforo-mycred-integration/">wpForo myCRED Integration</category>                        <dc:creator>kolex59</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-mycred-integration/mycred-plugin-is-not-installed/#post-10336</guid>
