									myCRED Badges are displayed even though they are deleted ?? [HELP] - wpForo myCRED Integration				            </title>
            <link>https://gvectors.com/forum/wpforo-mycred-integration/mycred-badges-are-displayed-even-though-they-are-deleted-help/</link>
            <lastBuildDate>Wed, 18 Nov 2026 20:55:17 +0000</lastBuildDate>
                        <title>RE: myCRED Badges are displayed even though they are deleted ?? </title>
                        <link>https://gvectors.com/forum/wpforo-mycred-integration/mycred-badges-are-displayed-even-though-they-are-deleted-help/#post-19266</link>
                        <pubDate>Mon, 23 Dec 2019 05:10:55 +0000</pubDate>
                        <description><![CDATA[@astghikHi,In all other plugins what I&#039;m using it showing right but not in WpDiscuz.  Maybe you want to double check? Because you have integration with MyCred and from some reason is not wor...]]></description>
                        <content:encoded><![CDATA[<p>@astghik</p><p>Hi,</p><p>In all other plugins what I'm using it showing right but not in WpDiscuz. 3815,3816 </p><p>Maybe you want to double check? Because you have integration with MyCred and from some reason is not working with wpdiscuz only.</p><p>I think you guys should be deal with that issue not us.</p><p>Your integration obviously not working as it should. </p><p>Thanks!</p><p> </p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/wpforo-mycred-integration/">wpForo myCRED Integration</category>                        <dc:creator>MarkoZ</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-mycred-integration/mycred-badges-are-displayed-even-though-they-are-deleted-help/#post-19266</guid>
                        <link>https://gvectors.com/forum/wpforo-mycred-integration/mycred-badges-are-displayed-even-though-they-are-deleted-help/#post-19257</link>
                        <pubDate>Sat, 21 Dec 2019 16:39:36 +0000</pubDate>
                        <description><![CDATA[Hi,
@cyzzio
May I kindly ask if you find solution for this issue?
I&#039;m facing the same problem.
Thanks!
Marko]]></description>
                        <content:encoded><![CDATA[<p>Hi,</p>
<p>@cyzzio</p>
<p>May I kindly ask if you find solution for this issue?</p>
<p>I'm facing the same problem.</p>
<p>Thanks!</p>
<p>Marko</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-mycred-integration/mycred-badges-are-displayed-even-though-they-are-deleted-help/#post-19257</guid>
                        <link>https://gvectors.com/forum/wpforo-mycred-integration/mycred-badges-are-displayed-even-though-they-are-deleted-help/#post-14079</link>
                        <pubDate>Wed, 13 Mar 2019 14:33:51 +0000</pubDate>
                        <description><![CDATA[thank you&nbsp;]]></description>
                        <content:encoded><![CDATA[<p>thank you&nbsp;</p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/wpforo-mycred-integration/">wpForo myCRED Integration</category>                        <dc:creator>bandana</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-mycred-integration/mycred-badges-are-displayed-even-though-they-are-deleted-help/#post-14079</guid>
                        <link>https://gvectors.com/forum/wpforo-mycred-integration/mycred-badges-are-displayed-even-though-they-are-deleted-help/#post-14075</link>
                        <pubDate>Wed, 13 Mar 2019 14:09:53 +0000</pubDate>
                        <description><![CDATA[You can use one of these forums:]]></description>
                        <content:encoded><![CDATA[<p>You can use one of these forums: </p><p>https://www.mycred.me/support/forums/forum/community/</p><p>https://wordpress.org/support/plugin/mycred/</p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/wpforo-mycred-integration/">wpForo myCRED Integration</category>                        <dc:creator>Astghik</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-mycred-integration/mycred-badges-are-displayed-even-though-they-are-deleted-help/#post-14075</guid>
                        <link>https://gvectors.com/forum/wpforo-mycred-integration/mycred-badges-are-displayed-even-though-they-are-deleted-help/#post-14073</link>
                        <pubDate>Wed, 13 Mar 2019 14:07:26 +0000</pubDate>
                        <description><![CDATA[And how can i contact the MyCred plugin support ???]]></description>
                        <content:encoded><![CDATA[<p>And how can i contact the MyCred plugin support ???</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-mycred-integration/mycred-badges-are-displayed-even-though-they-are-deleted-help/#post-14073</guid>
                        <link>https://gvectors.com/forum/wpforo-mycred-integration/mycred-badges-are-displayed-even-though-they-are-deleted-help/#post-14072</link>
                        <pubDate>Wed, 13 Mar 2019 14:05:12 +0000</pubDate>
                        <description><![CDATA[Hi @cyzzio,We&#039;ve checked this and found that the issue comes from the myCred plugin. You should ask this question to MyCred plugin support.]]></description>
                        <content:encoded><![CDATA[<p>Hi @cyzzio,</p><p>We've checked this and found that the issue comes from the myCred plugin. You should ask this question to MyCred plugin support. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-mycred-integration/mycred-badges-are-displayed-even-though-they-are-deleted-help/#post-14072</guid>
                        <title>myCRED Badges are displayed even though they are deleted ?? </title>
                        <link>https://gvectors.com/forum/wpforo-mycred-integration/mycred-badges-are-displayed-even-though-they-are-deleted-help/#post-14066</link>
                        <pubDate>Wed, 13 Mar 2019 11:36:56 +0000</pubDate>
                        <description><![CDATA[I just bought your plugin and I thought I&#039;d try this badges feature right away When I just created my first badges for a test and manually assigned it to one of my users, I noticed after del...]]></description>
                        <content:encoded><![CDATA[<p>I just bought your plugin and I thought I'd try this badges feature right away When I just created my first badges for a test and manually assigned it to one of my users, I noticed after deleting the badge that it was still under his user description and in the comment Avatar line of him. How can that be ?? How can I fix this?</p><p>2990,2989,2988</p><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-mycred-integration/mycred-badges-are-displayed-even-though-they-are-deleted-help/#post-14066</guid>
