									installation problems - wpForo Emoticons				            </title>
            <link>https://gvectors.com/forum/wpforo-emoticons/installation-problems/</link>
            <lastBuildDate>Thu, 12 Nov 2026 19:12:37 +0000</lastBuildDate>
                        <title>RE: installation problems</title>
                        <link>https://gvectors.com/forum/wpforo-emoticons/installation-problems/#post-17579</link>
                        <pubDate>Thu, 05 Sep 2019 21:30:58 +0000</pubDate>
                        <description><![CDATA[@fer912
I&#039;d recommend use this CSS code to make your forum look more professional. Please put this CSS code in Dashboard &gt; Forums &gt; Settings &gt; Styes Tab &gt; Custom CSS Code textar...]]></description>
                        <content:encoded><![CDATA[<p>@fer912</p>
<p>I'd recommend use this CSS code to make your forum look more professional. Please put this CSS code in Dashboard &gt; Forums &gt; Settings &gt; Styes Tab &gt; Custom CSS Code textarea. Save it, delete all caches, navigate to forum front-end and press Ctrl+F5 to reset browser cache:</p>
<pre>#wpforo-wrap, #wpforo-wrap .wpf-breadcrumb div:after, #wpforo-wrap .wpf-breadcrumb div.active, #wpforo-wrap .wpf-breadcrumb div:hover, #wpforo-wrap .wpf-breadcrumb div.active:after{<br />&nbsp;&nbsp;&nbsp;&nbsp; background: transparent!important;<br />}<br /><br />#wpforo-wrap .wpforo-profile-wrap{<br />&nbsp;&nbsp;&nbsp;&nbsp; background: #FFFFFF; padding:2%;<br />}</pre>
<p>3519</p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/wpforo-emoticons/">wpForo Emoticons</category>                        <dc:creator>Tom</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-emoticons/installation-problems/#post-17579</guid>
                        <link>https://gvectors.com/forum/wpforo-emoticons/installation-problems/#post-17577</link>
                        <pubDate>Thu, 05 Sep 2019 19:28:10 +0000</pubDate>
                        <description><![CDATA[it&#039;s working thanks again  {green}:hi:]]></description>
                        <content:encoded><![CDATA[<p>it's working thanks again  {green}:hi:  </p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/wpforo-emoticons/">wpForo Emoticons</category>                        <dc:creator>Fernando Ortiz</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-emoticons/installation-problems/#post-17577</guid>
                        <link>https://gvectors.com/forum/wpforo-emoticons/installation-problems/#post-17576</link>
                        <pubDate>Thu, 05 Sep 2019 15:49:08 +0000</pubDate>
The issue is solved by our developers. Please check it.
Don&#039;t forget to press CTRL+F5 (twice) on the frontend before checking.&nbsp;
&nbsp;]]></description>
<p>The issue is solved by our developers. Please check it.</p>
<p>Don't forget to press CTRL+F5 (twice) on the frontend before checking.&nbsp;</p>
<p>&nbsp;</p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/wpforo-emoticons/">wpForo Emoticons</category>                        <dc:creator>Astghik</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-emoticons/installation-problems/#post-17576</guid>
                        <link>https://gvectors.com/forum/wpforo-emoticons/installation-problems/#post-17575</link>
                        <pubDate>Thu, 05 Sep 2019 13:29:30 +0000</pubDate>
                        <description><![CDATA[sending thanks]]></description>
                        <content:encoded><![CDATA[<p>sending thanks</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-emoticons/installation-problems/#post-17575</guid>
                        <link>https://gvectors.com/forum/wpforo-emoticons/installation-problems/#post-17571</link>
                        <pubDate>Thu, 05 Sep 2019 12:34:14 +0000</pubDate>
                        <description><![CDATA[@fer912,
please send the login details to infogvectors.com email address.&nbsp;]]></description>
                        <content:encoded><![CDATA[<p>@fer912,</p>
<p>please send the login details to infogvectors.com email address.&nbsp;</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-emoticons/installation-problems/#post-17571</guid>
                        <link>https://gvectors.com/forum/wpforo-emoticons/installation-problems/#post-17570</link>
                        <pubDate>Thu, 05 Sep 2019 12:06:00 +0000</pubDate>
                        <description><![CDATA[Good morning, thanks for replying. I did what I recommended but it doesn&#039;t work, but I think it&#039;s more because I&#039;m very useless for this hahaha. I could pass you the data, so you can review ...]]></description>
                        <content:encoded><![CDATA[<p>Good morning, thanks for replying. I did what I recommended but it doesn't work, but I think it's more because I'm very useless for this hahaha. I could pass you the data, so you can review it. Excuse me again and thanks</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-emoticons/installation-problems/#post-17570</guid>
                        <link>https://gvectors.com/forum/wpforo-emoticons/installation-problems/#post-17559</link>
                        <pubDate>Thu, 05 Sep 2019 08:56:21 +0000</pubDate>
                        <description><![CDATA[Hi @fer912,Thank you for your purchase. Please navigate to Dashboard &gt; forums &gt; Dashboard admin page, click on the  button. If you use some other cache plugins pleas...]]></description>
                        <content:encoded><![CDATA[<p>Hi @fer912,</p><p>Thank you for your purchase. </p><p>Please navigate to Dashboard &gt; forums &gt; Dashboard admin page, click on the  button. If you use some other cache plugins please delete tose plugin caches as well. Then press CTRL+F5 (twice) on the frontend. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-emoticons/installation-problems/#post-17559</guid>
                        <title>installation problems</title>
                        <link>https://gvectors.com/forum/wpforo-emoticons/installation-problems/#post-17547</link>
                        <pubDate>Thu, 05 Sep 2019 00:30:13 +0000</pubDate>
                        <description><![CDATA[good morning, I bought the complement of emoticons, install and activate it, I can see it in add-ons but I cannot see it in the forum. what am I doing wrong? Thank you]]></description>
                        <content:encoded><![CDATA[<p><span lang="en">good morning, I bought the complement of emoticons, install and activate it, I can see it in add-ons but I cannot see it in the forum. what am I doing wrong? </span></p><p><span lang="en">Thank you</span></p><p>3516 3517 </p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-emoticons/installation-problems/#post-17547</guid>
