									Images from galleries are squashed in cross posts to forums - wpForo Blog Cross Posting				            </title>
            <link>https://gvectors.com/forum/wpforo-blog-cross-posting/images-from-galleries-are-squashed-in-cross-posts-to-forums/</link>
            <lastBuildDate>Wed, 09 Sep 2026 00:23:57 +0000</lastBuildDate>
                        <title>RE: Images from galleries are squashed in cross posts to forums</title>
                        <link>https://gvectors.com/forum/wpforo-blog-cross-posting/images-from-galleries-are-squashed-in-cross-posts-to-forums/#post-40867</link>
                        <pubDate>Thu, 14 Nov 2024 12:37:10 +0000</pubDate>
                        <description><![CDATA[@astgh should that not be covered by plugin? I&#039;m using a core feature of Wordpress.]]></description>
                        <content:encoded><![CDATA[@astgh should that not be covered by plugin? I'm using a core feature of Wordpress.]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/wpforo-blog-cross-posting/">wpForo Blog Cross Posting</category>                        <dc:creator>marsm</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-blog-cross-posting/images-from-galleries-are-squashed-in-cross-posts-to-forums/#post-40867</guid>
                        <link>https://gvectors.com/forum/wpforo-blog-cross-posting/images-from-galleries-are-squashed-in-cross-posts-to-forums/#post-40865</link>
                        <pubDate>Thu, 14 Nov 2024 12:11:19 +0000</pubDate>
                        <description><![CDATA[Hi,In this case, you should write custom CSS to fix the issue. All styles are being cross-posted, and in your case, the result doesn’t look correct. The cross-posting add-on cannot remove th...]]></description>
                        <content:encoded><![CDATA[<p>Hi,<br /><br />In this case, you should write custom CSS to fix the issue. All styles are being cross-posted, and in your case, the result doesn’t look correct. The cross-posting add-on cannot remove the styles when it cross-posts images.</p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/wpforo-blog-cross-posting/">wpForo Blog Cross Posting</category>                        <dc:creator>Astghik</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-blog-cross-posting/images-from-galleries-are-squashed-in-cross-posts-to-forums/#post-40865</guid>
                        <title>Images from galleries are squashed in cross posts to forums</title>
                        <link>https://gvectors.com/forum/wpforo-blog-cross-posting/images-from-galleries-are-squashed-in-cross-posts-to-forums/#post-40864</link>
                        <pubDate>Wed, 13 Nov 2024 16:45:57 +0000</pubDate>
                        <description><![CDATA[I&#039;ve noticed that images that are in galleries are all &quot;squashed&quot; when cross posted to the forums. Please see example here:&#039;s the original post for cross reference:]]></description>
                        <content:encoded><![CDATA[<p>I've noticed that images that are in galleries are all "squashed" when cross posted to the forums. Please see example here: <a href="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/my-octopus-cosy-6-heat-pump-journey-from-quote-to-completion#post-37453">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/my-octopus-cosy-6-heat-pump-journey-from-quote-to-completion#post-37453</a><br /><br />Here's the original post for cross reference: <a href="https://renewableheatinghub.co.uk/my-octopus-cosy-6-heat-pump-journey-from-quote-to-completion">https://renewableheatinghub.co.uk/my-octopus-cosy-6-heat-pump-journey-from-quote-to-completion</a> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-blog-cross-posting/images-from-galleries-are-squashed-in-cross-posts-to-forums/#post-40864</guid>
