									Refund Request for Order - wpForo Advanced Attachments				            </title>
            <link>https://gvectors.com/forum/wpforo-advanced-attachments/refund-request-for-order/</link>
            <lastBuildDate>Thu, 10 Sep 2026 13:59:02 +0000</lastBuildDate>
                        <title>RE: Refund Request for Order</title>
                        <link>https://gvectors.com/forum/wpforo-advanced-attachments/refund-request-for-order/paged/2/#post-42608</link>
                        <pubDate>Sat, 31 Jan 2026 00:27:00 +0000</pubDate>
                        <description><![CDATA[@astgh The CSS code does not change with updates anyway. In order to make it look the same as on the website I modified files such as  class.wpForoAttachmentsTools.php; however, these files ...]]></description>
                        <content:encoded><![CDATA[@astgh The CSS code does not change with updates anyway. <strong data-start="82" data-end="167">In order to make it look the same as on the website (<a class="decorated-link" href="https://gvectors.com/forum" target="_new" rel="noopener" data-start="137" data-end="163">https://gvectors.com/forum<span class="ms-0.5 inline-block align-middle leading-none" aria-hidden="true"></span></a>),</strong> I modified files such as <span> class.wpForoAttachmentsTools.php</span>; however, these files will be overwritten during updates. This is not an issue caused by the website itself. I also installed and tested it on a clean website, and the same issues persist. Both the plugin and Elementor are on their latest versions.<br /><br />The code on the demo website provided is definitely not the same as the code of the version I purchased. I recreated it by carefully checking the HTML line by line, but it will break again when an update is released.]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/wpforo-advanced-attachments/">wpForo Advanced Attachments</category>                        <dc:creator>kuzgunkkk</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-advanced-attachments/refund-request-for-order/paged/2/#post-42608</guid>
                        <link>https://gvectors.com/forum/wpforo-advanced-attachments/refund-request-for-order/paged/2/#post-42607</link>
                        <pubDate>Fri, 30 Jan 2026 08:28:44 +0000</pubDate>
                        <description><![CDATA[@kuzgunkkk
Insert the CSS Code in the &quot;Custom CSS Code&quot; textarea in the wpForo &gt; Settings &gt; Colors &amp; Styles admin page.]]></description>
                        <content:encoded><![CDATA[<p data-start="50" data-end="62">@kuzgunkkk</p>
<p data-start="69" data-end="156"><span>Insert the CSS Code in the "</span><a href="https://wpforo.com/docs/wpforo-v2/settings/colors-styles/#custom-css-code" target="_blank" rel="noopener">Custom CSS Code</a><span>" textarea in the wpForo &gt; Settings &gt; Colors &amp; Styles admin page. </span></p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/wpforo-advanced-attachments/">wpForo Advanced Attachments</category>                        <dc:creator>Astghik</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-advanced-attachments/refund-request-for-order/paged/2/#post-42607</guid>
                        <link>https://gvectors.com/forum/wpforo-advanced-attachments/refund-request-for-order/paged/2/#post-42606</link>
                        <pubDate>Thu, 29 Jan 2026 23:33:27 +0000</pubDate>
                        <description><![CDATA[class.wpForoAttachmentsListTable.php I completed the codes and they work correctly, but they will break with updates. Is there an easy way to do this?
@astgh]]></description>
                        <content:encoded><![CDATA[<span><span> class.wpForoAttachmentsListTable.php <br /><br />I completed the codes and they work correctly, but they will break with updates. Is there an easy way to do this?</span></span>
<p>@astgh </p>
7833
<span> <br /></span>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-advanced-attachments/refund-request-for-order/paged/2/#post-42606</guid>
                        <link>https://gvectors.com/forum/wpforo-advanced-attachments/refund-request-for-order/#post-42605</link>
                        <pubDate>Thu, 29 Jan 2026 22:55:02 +0000</pubDate>
                        <description><![CDATA[figure {
 display: inline-block;
 cursor: move !important;
 margin: 5px;
}i don&#039;t have this place]]></description>
                        <content:encoded><![CDATA[<div class="styles-section-title styles-selector">
<div class="selector-container"><span class="selector" aria-label="CSS selector"><span class="simple-selector selector-matches" aria-describedby="specificity-tooltip-389">figure</span></span><span></span><span class="sidebar-pane-open-brace"><span> </span>{</span></div>
</div>
<div class="style-properties matched-styles monospace">
<div class="tree-outline-disclosure">
<ol class="tree-outline" role="tree">
<li role="treeitem"><span class="styles-clipboard-only"> </span><span class="webkit-css-property" aria-label="CSS property name: display" aria-details="swatch-tooltip-226-display-0-property-doc-0">display</span><span class="styles-name-value-separator">: </span><span class="value" aria-label="CSS property value: inline-block"><span>inline-block</span></span><span class="styles-semicolon">;</span></li>
<li role="treeitem"><span class="styles-clipboard-only"> </span><span class="webkit-css-property" aria-label="CSS property name: cursor" aria-details="swatch-tooltip-226-cursor-0-property-doc-0">cursor</span><span class="styles-name-value-separator">: </span><span class="value" aria-label="CSS property value: move !important"><span>move</span><span> </span><span>!important</span></span><span class="styles-semicolon">;</span></li>
<li class="parent" role="treeitem" aria-expanded="false"><span class="styles-clipboard-only"> </span><span class="webkit-css-property" aria-label="CSS property name: margin" aria-details="swatch-tooltip-226-margin-0-property-doc-0">margin</span><span class="styles-name-value-separator">: </span><span class="value" aria-label="CSS property value: 5px"><span>5px</span></span><span class="styles-semicolon">;</span></li>
</ol>
</div>
</div>
<div class="sidebar-pane-closing-brace"><span class="styles-clipboard-only"></span><span>}<br /><br /><br />i don't have this place</span></div>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-advanced-attachments/refund-request-for-order/#post-42605</guid>
                        <link>https://gvectors.com/forum/wpforo-advanced-attachments/refund-request-for-order/#post-42604</link>
                        <pubDate>Thu, 29 Jan 2026 21:50:02 +0000</pubDate>
                        <description><![CDATA[I have already resolved the other issues myself using CSS.The remaining problem is related to the image container size.
On your website, when an image is uploaded, the container appears wid...]]></description>
                        <content:encoded><![CDATA[7831
7830
<p data-start="207" data-end="329">I have already resolved the other issues myself using CSS.<br data-start="265" data-end="268" />The remaining problem is related to the image container size.</p>
<p data-start="331" data-end="554">On your website, when an image is uploaded, the container appears wider than the image itself, which causes an incorrect layout.<br data-start="459" data-end="462" />One image example is from your website, and the other one is from my website for comparison.</p>
<p data-start="556" data-end="654">I’ve attached both images to clearly show the difference.<br data-start="613" data-end="616" />Thank you in advance for your support.<br /><br />url: https://cospier.com/cosplay-forum/bulusma-planlama/kimi-online-cosplay-turnuvasi</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-advanced-attachments/refund-request-for-order/#post-42604</guid>
                        <link>https://gvectors.com/forum/wpforo-advanced-attachments/refund-request-for-order/#post-42589</link>
                        <pubDate>Mon, 26 Jan 2026 09:47:45 +0000</pubDate>
Please provide the URL where we can check the issue.]]></description>
                        <content:encoded><![CDATA[<p>@kuzgunkkk </p>
<p>Please provide the URL where we can check the issue. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-advanced-attachments/refund-request-for-order/#post-42589</guid>
                        <link>https://gvectors.com/forum/wpforo-advanced-attachments/refund-request-for-order/#post-42588</link>
                        <pubDate>Mon, 26 Jan 2026 09:45:36 +0000</pubDate>
                        <description><![CDATA[the settings are already that way]]></description>
                        <content:encoded><![CDATA[7828
<p>the settings are already that way</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-advanced-attachments/refund-request-for-order/#post-42588</guid>
                        <link>https://gvectors.com/forum/wpforo-advanced-attachments/refund-request-for-order/#post-42587</link>
                        <pubDate>Mon, 26 Jan 2026 09:39:57 +0000</pubDate>
Please make sure the &quot;Attachment Lightbox/Slider&quot; option is enabled. You can locate and manage the option in the Dashboard &gt; wpForo &gt; Settings &gt; Addons Settings &gt; Ad...]]></description>
<p>Please make sure the "Attachment Lightbox/Slider" option is enabled. You can locate and manage the option in the Dashboard &gt; wpForo &gt; Settings &gt; Addons Settings &gt; Advanced Attachments admin page. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-advanced-attachments/refund-request-for-order/#post-42587</guid>
                        <link>https://gvectors.com/forum/wpforo-advanced-attachments/refund-request-for-order/#post-42585</link>
                        <pubDate>Mon, 26 Jan 2026 00:34:28 +0000</pubDate>
                        <description><![CDATA[I upgraded from an older version to the latest one, but the issues still haven’t been fixed. When I click on an image, there is no back button to return. Also, when I upload an image, it app...]]></description>
                        <content:encoded><![CDATA[<p data-start="85" data-end="419">I upgraded from an older version to the latest one, but the issues still haven’t been fixed. When I click on an image, there is no back button to return. Also, when I upload an image, it appears squashed, and the images are displayed one under another, taking up the full width of the row. This doesn’t happen in the test environment.</p>
<p data-start="421" data-end="478" data-is-last-node="" data-is-only-node="">I would like to request a refund for my order <strong data-start="467" data-end="477">#49908</strong>.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-advanced-attachments/refund-request-for-order/#post-42585</guid>
                        <title>Refund Request for Order</title>
                        <link>https://gvectors.com/forum/wpforo-advanced-attachments/refund-request-for-order/#post-42584</link>
                        <pubDate>Mon, 26 Jan 2026 00:28:13 +0000</pubDate>
                        <description><![CDATA[Eski sürümden en yeni sürüme yükselttim, ancak sorunlar hala çözülmedi. Bir resme tıkladığımda geri dönmek için bir geri düğmesi yok. Ayrıca, bir resim yüklediğimde, resimler sıkıştırılmış g...]]></description>
                        <content:encoded><![CDATA[7825
7826
7827
<p data-start="0" data-end="334"><span style="vertical-align: inherit" dir="auto"><span style="vertical-align: inherit" dir="auto">Eski sürümden en yeni sürüme yükselttim, ancak sorunlar hala çözülmedi. Bir resme tıkladığımda geri dönmek için bir geri düğmesi yok. Ayrıca, bir resim yüklediğimde, resimler sıkıştırılmış görünüyor ve resimler alt alta, satırın tüm genişliğini kaplayacak şekilde görüntüleniyor. Bu durum test ortamında yaşanmıyor.</span></span></p>
<p data-start="336" data-end="393" data-is-last-node="" data-is-only-node=""><strong data-start="382" data-end="392"><span style="vertical-align: inherit" dir="auto"><span style="vertical-align: inherit" dir="auto">49908 numaralı</span></span></strong><span style="vertical-align: inherit" dir="auto"><span style="vertical-align: inherit" dir="auto"> siparişim için para iadesi talep etmek istiyorum </span><span style="vertical-align: inherit" dir="auto">.</span></span></p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-advanced-attachments/refund-request-for-order/#post-42584</guid>
