									Attachments not showing in BuddyBoss feed - wpForo Advanced Attachments				            </title>
            <link>https://gvectors.com/forum/wpforo-advanced-attachments/attachments-not-showing-in-buddyboss-feed/</link>
            <lastBuildDate>Fri, 14 Aug 2026 15:06:06 +0000</lastBuildDate>
                        <title>RE: Attachments not showing in BuddyBoss feed</title>
                        <link>https://gvectors.com/forum/wpforo-advanced-attachments/attachments-not-showing-in-buddyboss-feed/paged/2/#post-41262</link>
                        <pubDate>Tue, 04 Feb 2025 10:49:23 +0000</pubDate>
                        <description><![CDATA[Hi,
We&#039;ll check and fix the issue in near future versions.]]></description>
                        <content:encoded><![CDATA[<p>Hi,</p>
<p>We'll check and fix the issue in near future versions. </p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/wpforo-advanced-attachments/">wpForo Advanced Attachments</category>                        <dc:creator>Astghik</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-advanced-attachments/attachments-not-showing-in-buddyboss-feed/paged/2/#post-41262</guid>
                        <link>https://gvectors.com/forum/wpforo-advanced-attachments/attachments-not-showing-in-buddyboss-feed/#post-41258</link>
                        <pubDate>Sat, 01 Feb 2025 19:27:04 +0000</pubDate>
                        <description><![CDATA[Hi and thanks for your quick reply. After some investigation (and please correct me, if I am wrong), the issue seems to be simple, so i don&#039;t have to send my admin-login-details:To display u...]]></description>
                        <content:encoded><![CDATA[<p>Hi and thanks for your quick reply. After some investigation (and please correct me, if I am wrong), the issue seems to be simple, so i don't have to send my admin-login-details:<br /><br />To display user-attached files, the Attachement-Extension uses the internal Shortcode-Combination <span class="wpf-attachment-404">-- attachment is not available --</span> which include a Number referring to the id of the uploaded file - in my example the file with the ID 157. <br /><br />As the -code doesn't seem to work outside of wpforo, the attachements are not displayed properly, neither in buddypress, peepso or on any other page or post referring to that attachement, which is sad.<br /><br />So my hope is, you could make  also available for the whole wordpress-installation and then all should be fine.<br /><br />Hope this helps to clear uo the problem and I hope you can solve this asap.<br /><br />Best, Michael</p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/wpforo-advanced-attachments/">wpForo Advanced Attachments</category>                        <dc:creator>Michael Stallmeyer</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-advanced-attachments/attachments-not-showing-in-buddyboss-feed/#post-41258</guid>
                        <link>https://gvectors.com/forum/wpforo-advanced-attachments/attachments-not-showing-in-buddyboss-feed/#post-41255</link>
                        <pubDate>Fri, 31 Jan 2025 09:52:12 +0000</pubDate>
                        <description><![CDATA[@michael-stallmeyer 
Please send the admin login details to infogvectors.com email address. I&#039;ll ask the developers to check the issue for you.]]></description>
                        <content:encoded><![CDATA[<p>@michael-stallmeyer </p>
<p>Please send the admin login details to infogvectors.com email address. I'll ask the developers to check the issue for you.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-advanced-attachments/attachments-not-showing-in-buddyboss-feed/#post-41255</guid>
                        <link>https://gvectors.com/forum/wpforo-advanced-attachments/attachments-not-showing-in-buddyboss-feed/#post-41253</link>
                        <pubDate>Thu, 30 Jan 2025 22:53:50 +0000</pubDate>
                        <description><![CDATA[Has there been any solution to this? I&#039;m facing the same problem with my wpforo-integration in peepso :-(]]></description>
                        <content:encoded><![CDATA[<p>Has there been any solution to this? I'm facing the same problem with my wpforo-integration in peepso :-(</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-advanced-attachments/attachments-not-showing-in-buddyboss-feed/#post-41253</guid>
                        <link>https://gvectors.com/forum/wpforo-advanced-attachments/attachments-not-showing-in-buddyboss-feed/#post-41072</link>
                        <pubDate>Sun, 22 Dec 2024 10:51:11 +0000</pubDate>
                        <description><![CDATA[@webmasterstinsonclub-org please post the result if this is fixed as I am using BuddyBoss and am looking at purchasing this plugin but don&#039;t want it have to purchase both the plugin and Pro ...]]></description>
                        <content:encoded><![CDATA[@webmasterstinsonclub-org please post the result if this is fixed as I am using BuddyBoss and am looking at purchasing this plugin but don't want it have to purchase both the plugin and Pro Support.]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/wpforo-advanced-attachments/">wpForo Advanced Attachments</category>                        <dc:creator>freedman</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-advanced-attachments/attachments-not-showing-in-buddyboss-feed/#post-41072</guid>
                        <link>https://gvectors.com/forum/wpforo-advanced-attachments/attachments-not-showing-in-buddyboss-feed/#post-41062</link>
                        <pubDate>Fri, 20 Dec 2024 08:48:28 +0000</pubDate>
                        <content:encoded><![CDATA[<p>@webmasterstinsonclub-org </p>
<p>Please send the admin login details to infogvectors.com email address. I'll ask the developers to check the issue for you. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-advanced-attachments/attachments-not-showing-in-buddyboss-feed/#post-41062</guid>
                        <link>https://gvectors.com/forum/wpforo-advanced-attachments/attachments-not-showing-in-buddyboss-feed/#post-41046</link>
                        <pubDate>Mon, 16 Dec 2024 15:42:33 +0000</pubDate>
                        <description><![CDATA[well I have had this plug in in the past and it worked well. Then my license expired, I renewed and now it doesnt work. Buddyboss and WPForo do have an intergration and it&#039;s worked well in t...]]></description>
                        <content:encoded><![CDATA[<p>well I have had this plug in in the past and it worked well. Then my license expired, I renewed and now it doesnt work. <br /><br />Buddyboss and WPForo do have an intergration and it's worked well in the past, but not now. <br /><br />So you are saying I had to purchase the Attachments Plugin and now I have to purchase Pro support?</p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/wpforo-advanced-attachments/">wpForo Advanced Attachments</category>                        <dc:creator>wilson ware</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-advanced-attachments/attachments-not-showing-in-buddyboss-feed/#post-41046</guid>
                        <link>https://gvectors.com/forum/wpforo-advanced-attachments/attachments-not-showing-in-buddyboss-feed/#post-41045</link>
                        <pubDate>Mon, 16 Dec 2024 09:23:03 +0000</pubDate>
The wpForo wpForo Advanced Attachments addon doesn&#039;t have an integration with the BuddyBoss plugin. 
I&#039;d recommend purchasing pro support and reaching out to the pro support team for c...]]></description>
<p>The wpForo wpForo Advanced Attachments addon doesn't have an integration with the BuddyBoss plugin. </p>
<p>I'd recommend purchasing pro support and reaching out to the pro support team for customizations: https://wpforo.com/pro-support/#plugin-support</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-advanced-attachments/attachments-not-showing-in-buddyboss-feed/#post-41045</guid>
                        <title>Attachments not showing in BuddyBoss feed</title>
                        <link>https://gvectors.com/forum/wpforo-advanced-attachments/attachments-not-showing-in-buddyboss-feed/#post-41043</link>
                        <pubDate>Sun, 15 Dec 2024 19:33:55 +0000</pubDate>
                        <description><![CDATA[I have the attachment plugin for WPforo, and attachments are being accepted and show in WPForo, but the buddyboss activity feed is not showing the attachments. 
I have checked the accesses ...]]></description>
                        <content:encoded><![CDATA[<p>I have the attachment plugin for WPforo, and attachments are being accepted and show in WPForo, but the buddyboss activity feed is not showing the attachments. </p>
<p>I have checked the accesses and everything looks fine, any ideas?</p>
7499
<p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-advanced-attachments/attachments-not-showing-in-buddyboss-feed/#post-41043</guid>
