									Attaching images does not work? - wpForo Advanced Attachments				            </title>
            <link>https://gvectors.com/forum/wpforo-advanced-attachments/attaching-images-does-not-work/</link>
            <lastBuildDate>Mon, 18 May 2026 11:57:39 +0000</lastBuildDate>
                        <title>RE: Attaching images does not work?</title>
                        <link>https://gvectors.com/forum/wpforo-advanced-attachments/attaching-images-does-not-work/#post-36834</link>
                        <pubDate>Fri, 12 May 2023 09:11:55 +0000</pubDate>
                        <description><![CDATA[@christine-boyle,
Try deactivating your plugins, and then enable them one by one, if none of the plugins affect on the Attachments addon, also try to change your theme. Let me know the resu...]]></description>
                        <content:encoded><![CDATA[<p>@christine-boyle,</p>
<p>Try deactivating your plugins, and then enable them one by one, if none of the plugins affect on the Attachments addon, also try to change your theme. Let me know the results.</p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/wpforo-advanced-attachments/">wpForo Advanced Attachments</category>                        <dc:creator>Kyle</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-advanced-attachments/attaching-images-does-not-work/#post-36834</guid>
                        <link>https://gvectors.com/forum/wpforo-advanced-attachments/attaching-images-does-not-work/#post-36805</link>
                        <pubDate>Sat, 06 May 2023 15:30:41 +0000</pubDate>
                        <description><![CDATA[@kylew Hello, having investigated this via F12 using Chrome console I&#039;ve upgraded jQuery 3.6.4 that didn&#039;t fix it, so reviewed each versioning file but your code at wpfa_load_file using &quot;att...]]></description>
                        <content:encoded><![CDATA[@kylew Hello, having investigated this via F12 using Chrome console I've upgraded jQuery 3.6.4 that didn't fix it, so reviewed each versioning file but your code at wpfa_load_file using "attach.js?ver 3.1.1:265" points this part =&gt;  jQuery.ajax({<br />url: loadZone.fileupload('option', 'url'),<br />data: { <br /><br />The JS error is coming from your wpforo attachment plugin.
6782]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/wpforo-advanced-attachments/">wpForo Advanced Attachments</category>                        <dc:creator>Christine Boyle</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-advanced-attachments/attaching-images-does-not-work/#post-36805</guid>
                        <link>https://gvectors.com/forum/wpforo-advanced-attachments/attaching-images-does-not-work/#post-36757</link>
                        <pubDate>Sat, 29 Apr 2023 09:09:47 +0000</pubDate>
Open the Test post link, press on My Media button, then press F12 and select Console Tab you would see there JS errors, you need to fix them.]]></description>
<p>Open the Test post <a href="https://www.colourandcloth.co.uk/sewing-community-forum-ireland/vintage-machines/electric-cables-on-vintage-machines/#post-65" target="_blank" rel="noopener">link</a>, press on My Media button, then press F12 and select Console Tab you would see there JS errors, you need to fix them.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-advanced-attachments/attaching-images-does-not-work/#post-36757</guid>
                        <link>https://gvectors.com/forum/wpforo-advanced-attachments/attaching-images-does-not-work/#post-36747</link>
                        <pubDate>Fri, 28 Apr 2023 09:49:50 +0000</pubDate>
                        <description><![CDATA[This is the &quot;TEST&quot; post
It only provides a hyperlink and the functions Insert in Post do not work or display the images being attached.]]></description>
                        <content:encoded><![CDATA[<p>This is the "TEST" post https://www.colourandcloth.co.uk/sewing-community-forum-ireland/vintage-machines/electric-cables-on-vintage-machines/#post-65 </p>
<p>It only provides a hyperlink and the functions Insert in Post do not work or display the images being attached.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-advanced-attachments/attaching-images-does-not-work/#post-36747</guid>
                        <link>https://gvectors.com/forum/wpforo-advanced-attachments/attaching-images-does-not-work/#post-36746</link>
                        <pubDate>Fri, 28 Apr 2023 09:48:35 +0000</pubDate>
                        <description><![CDATA[Here you go]]></description>
                        <content:encoded><![CDATA[<p>Here you go https://www.colourandcloth.co.uk/sewing-community-forum-ireland/ </p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-advanced-attachments/attaching-images-does-not-work/#post-36746</guid>
                        <link>https://gvectors.com/forum/wpforo-advanced-attachments/attaching-images-does-not-work/#post-36744</link>
                        <pubDate>Fri, 28 Apr 2023 09:45:42 +0000</pubDate>
                        <description><![CDATA[Hi @christine-boyle,
Please provide forum URL.]]></description>
                        <content:encoded><![CDATA[<p>Hi <span>@christine-boyle,</span></p>
<p>Please provide forum URL.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-advanced-attachments/attaching-images-does-not-work/#post-36744</guid>
                        <title>Attaching images does not work?</title>
                        <link>https://gvectors.com/forum/wpforo-advanced-attachments/attaching-images-does-not-work/#post-36742</link>
                        <pubDate>Fri, 28 Apr 2023 08:44:22 +0000</pubDate>
                        <description><![CDATA[Hi,I paid for this Attachment addon but it won&#039;t work or does not work. I&#039;ve been trying to add images but it does nothing no error indicated and no actions. I&#039;ve search the forums for any c...]]></description>
                        <content:encoded><![CDATA[<p>Hi,<br /><br />I paid for this Attachment addon but it won't work or does not work. I've been trying to add images but it does nothing no error indicated and no actions. I've search the forums for any clues to this issue. The function of "My Media" brings up the Red and Green boxes to add files, I add files to list then try Drag &amp; Drop or the select box options ADD TO POST and nothing happens.<br /><br />Any help to fix this would be appreciated.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-advanced-attachments/attaching-images-does-not-work/#post-36742</guid>
