									Advanced Attachments Preferences not saving. - wpForo Advanced Attachments				            </title>
            <link>https://gvectors.com/forum/wpforo-advanced-attachments/advanced-attachments-preferences-not-saving/</link>
            <lastBuildDate>Mon, 20 Jul 2026 16:15:51 +0000</lastBuildDate>
                        <title>RE: Advanced Attachments Preferences not saving.</title>
                        <link>https://gvectors.com/forum/wpforo-advanced-attachments/advanced-attachments-preferences-not-saving/#post-40627</link>
                        <pubDate>Wed, 25 Sep 2024 17:17:40 +0000</pubDate>
                        <description><![CDATA[@tutrix ahhhhh.... That worked!]]></description>
                        <content:encoded><![CDATA[@tutrix ahhhhh.... That worked!]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/wpforo-advanced-attachments/">wpForo Advanced Attachments</category>                        <dc:creator>Craig Cotner</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-advanced-attachments/advanced-attachments-preferences-not-saving/#post-40627</guid>
                        <link>https://gvectors.com/forum/wpforo-advanced-attachments/advanced-attachments-preferences-not-saving/#post-40626</link>
                        <pubDate>Wed, 25 Sep 2024 17:08:39 +0000</pubDate>
                        <description><![CDATA[@craig-cotner 
If the lightbox is disabled, the code looks like this,
&quot;lightbox&quot;;i:0;s:16:&quot;
but make a backup of the database before you change anything]]></description>
                        <content:encoded><![CDATA[<p>@craig-cotner </p>
<p>If the lightbox is disabled, the code looks like this,</p>
<pre contenteditable="false">"lightbox";i:0;s:16:"</pre>
<p>but make a backup of the database before you change anything</p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/wpforo-advanced-attachments/">wpForo Advanced Attachments</category>                        <dc:creator>Tutrix</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-advanced-attachments/advanced-attachments-preferences-not-saving/#post-40626</guid>
                        <link>https://gvectors.com/forum/wpforo-advanced-attachments/advanced-attachments-preferences-not-saving/#post-40624</link>
                        <pubDate>Wed, 25 Sep 2024 13:54:07 +0000</pubDate>
Unfortunately that did not fix the problem. I turned off all plugins except the WPForo ones. I even switched to the standard 2024 theme just incase something with the theme was cau...]]></description>
                        <content:encoded><![CDATA[<p>@tutrix </p>
<p>Unfortunately that did not fix the problem. I turned off all plugins except the WPForo ones. I even switched to the standard 2024 theme just incase something with the theme was causing the problem. But no luck at all.</p>
<p>Is there an update I can make within the database table itself to switch the lightbox to disabled? I can see the lightbox setting within the "wpforo_attach_options" record in the main Options table. But I do not know what I need to change it to get this to work.</p>
<p>Here is the code around the lightbox, so it is more than just the lightbox.</p>
<p> </p>
<p>"boxed";i:0;s:8:<strong>"lightbox"</strong>;i:1;s:16:"download_via_php";i:0;}</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-advanced-attachments/advanced-attachments-preferences-not-saving/#post-40624</guid>
                        <link>https://gvectors.com/forum/wpforo-advanced-attachments/advanced-attachments-preferences-not-saving/#post-40623</link>
                        <pubDate>Wed, 25 Sep 2024 10:35:28 +0000</pubDate>
                        <description><![CDATA[Hi @craig-cotner
I think it&#039;s a conflict with another plugin or a JS minification by a pluginDeactivate the plugins (except wpForo plugins) and try again.]]></description>
                        <content:encoded><![CDATA[<p>Hi @craig-cotner</p>
<p></p>
<p>Any settings in Advanced Attachments never get saved.</p>
<p></p>
<p>I think it's a conflict with another plugin or a JS minification by a plugin<br />Deactivate the plugins (except wpForo plugins) and try again.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-advanced-attachments/advanced-attachments-preferences-not-saving/#post-40623</guid>
                        <link>https://gvectors.com/forum/wpforo-advanced-attachments/advanced-attachments-preferences-not-saving/#post-40619</link>
                        <pubDate>Tue, 24 Sep 2024 17:44:30 +0000</pubDate>
                        <description><![CDATA[Still having this issue. Any settings in Advanced Attachments never get saved. Nothing actually happens when I click the same button. 
I would like to disable the lightbox setting, but I ha...]]></description>
                        <content:encoded><![CDATA[<p>Still having this issue. Any settings in Advanced Attachments never get saved. Nothing actually happens when I click the same button. </p>
<p>I would like to disable the lightbox setting, but I have not found a way to do this in the front end. I click save, nothing happens. I even clear the WPForo cache and still nothing.</p>
<p>I would try again to make this change on the backend, but have not been about to figure it out in the <span>wpforo_attach_options table.</span> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-advanced-attachments/advanced-attachments-preferences-not-saving/#post-40619</guid>
                        <title>Advanced Attachments Preferences not saving.</title>
                        <link>https://gvectors.com/forum/wpforo-advanced-attachments/advanced-attachments-preferences-not-saving/#post-36414</link>
                        <pubDate>Fri, 24 Mar 2023 16:34:37 +0000</pubDate>
                        <description><![CDATA[I am having trouble SAVING any preferences for Advanced Attachments. I have had this issue in the past and have just found the setting in the backend and manually updated it.
But now I want...]]></description>
                        <content:encoded><![CDATA[<p>I am having trouble SAVING any preferences for Advanced Attachments. I have had this issue in the past and have just found the setting in the backend and manually updated it.</p>
<p>But now I want to change the setting that will allow users to delete their own attachments, but each time I try to save the settings. Nothing happens. </p>
<p> </p>
<p>Where can I find this setting in the backend database so I can hopefully change it?</p>
<p> </p>
6677]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpforo-advanced-attachments/advanced-attachments-preferences-not-saving/#post-36414</guid>
