									Top Rated Comments - Comment Rating - wpDiscuz Widgets				            </title>
            <link>https://gvectors.com/forum/wpdiscuz-widgets/top-rated-comments-comment-rating/</link>
            <lastBuildDate>Sat, 08 Aug 2026 13:44:40 +0000</lastBuildDate>
                        <title>RE: Top Rated Comments - Comment Rating</title>
                        <link>https://gvectors.com/forum/wpdiscuz-widgets/top-rated-comments-comment-rating/#post-40567</link>
                        <pubDate>Sun, 15 Sep 2024 00:46:13 +0000</pubDate>
                        <description><![CDATA[FYI I was able to achieve this by using the &#039;wpdiscuz_after_comment_post&#039; hook to populate a custom meta field with my combined average rating, # of rating votes, and most recent comment dat...]]></description>
                        <content:encoded><![CDATA[<p>FYI I was able to achieve this by using the 'wpdiscuz_after_comment_post' hook to populate a custom meta field with my combined average rating, # of rating votes, and most recent comment date/time.  This allows me to use a query loop (Generate Blocks) in my sidebar with a query that is ordered by any of these meta fields, so I can create my own 'Top Rated', 'Most Recent', 'Most Active' etc.</p>
<p>The combined average rating of multiple rating blocks is discussed here - <a href="https://wordpress.org/support/topic/wpdisuz-calculate-total-comment-rating/#post-18014164" target="_blank" rel="noopener">https://wordpress.org/support/topic/wpdisuz-calculate-total-comment-rating/#post-18014164</a></p>
<p> </p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/wpdiscuz-widgets/">wpDiscuz Widgets</category>                        <dc:creator>Brendan Shanahan</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-widgets/top-rated-comments-comment-rating/#post-40567</guid>
                        <link>https://gvectors.com/forum/wpdiscuz-widgets/top-rated-comments-comment-rating/#post-40561</link>
                        <pubDate>Fri, 13 Sep 2024 13:59:03 +0000</pubDate>
                        <description><![CDATA[Hi Brendan Shanahan,
 Top Rated Comments tab in the widget is blank, I assume this is because it only works on article ratings?
Yes, this works only on article ratings. 
Is there a ...]]></description>
                        <content:encoded><![CDATA[<p>Hi Brendan Shanahan,</p>
<blockquote>
<p><span> Top Rated Comments tab in the widget is blank, I assume this is because it only works on article ratings?</span></p>
</blockquote>
<p>Yes, this works only on article ratings. </p>
<blockquote>
<p><span>Is there a way to display the top-rated posts, by a designated comment rating meta key?</span></p>
</blockquote>
<p>I've already asked the developers to check if it's possible to make these changes in the addon core.</p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/wpdiscuz-widgets/">wpDiscuz Widgets</category>                        <dc:creator>Astghik</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-widgets/top-rated-comments-comment-rating/#post-40561</guid>
                        <title>Top Rated Comments - Comment Rating</title>
                        <link>https://gvectors.com/forum/wpdiscuz-widgets/top-rated-comments-comment-rating/#post-40546</link>
                        <pubDate>Thu, 12 Sep 2024 03:44:24 +0000</pubDate>
                        <description><![CDATA[I am setting up a new site that is using comment ratings as I need multiple ratings per article (e.g. Quality, Performance, Overall etc), however the Top Rated Comments tab in the widget is ...]]></description>
                        <content:encoded><![CDATA[<p>I am setting up a new site that is using comment ratings as I need multiple ratings per article (e.g. Quality, Performance, Overall etc), however the Top Rated Comments tab in the widget is blank, I assume this is because it only works on article ratings?</p>
<p> </p>
<p>Is there a way to display the top-rated posts, by a designated comment rating meta key?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-widgets/top-rated-comments-comment-rating/#post-40546</guid>
