									Format Problems - wpDiscuz Subscription Manager				            </title>
            <link>https://gvectors.com/forum/wpdiscuz-subscription-manager/format-problems/</link>
            <lastBuildDate>Tue, 09 Jun 2026 18:51:18 +0000</lastBuildDate>
                        <title>RE: Format Problems</title>
                        <link>https://gvectors.com/forum/wpdiscuz-subscription-manager/format-problems/#post-27863</link>
                        <pubDate>Tue, 30 Mar 2021 07:54:14 +0000</pubDate>
                        <description><![CDATA[@nick776,
You can use the CSS code below: 
#wpdcom .wpdiscuz-item.wpd-field-checkbox.wpd-field-single {
  text-align: left !important;
Put the code in the Top Admin Bar &gt; Customize...]]></description>
                        <content:encoded><![CDATA[<p>@nick776,</p>
<p>You can use the CSS code below: </p>
<pre contenteditable="false">#wpdcom .wpdiscuz-item.wpd-field-checkbox.wpd-field-single {
}</pre>
<p>Put the code in the <em>Top Admin Bar &gt; Customize &gt; Additional CSS &gt; "Additional CSS"</em> textarea, save it, delete all caches and check again. </p>
<p>Please don't forget to press Ctrl+F5 (twice) on the frontend before checking.</p>
<blockquote>
<p><span>and by mobile (iPhone 8plus) you can see there is a format-problem too</span></p>
</blockquote>
<p>This designed to work in this way. you can check it here: https://wpdiscuz.com/demo/</p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/wpdiscuz-subscription-manager/">wpDiscuz Subscription Manager</category>                        <dc:creator>Astghik</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-subscription-manager/format-problems/#post-27863</guid>
                        <link>https://gvectors.com/forum/wpdiscuz-subscription-manager/format-problems/#post-27862</link>
                        <pubDate>Tue, 30 Mar 2021 07:46:41 +0000</pubDate>
                        <description><![CDATA[@astghik good morning astghik, did you need more informations?]]></description>
                        <content:encoded><![CDATA[@astghik good morning astghik, did you need more informations?]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/wpdiscuz-subscription-manager/">wpDiscuz Subscription Manager</category>                        <dc:creator>Nick776</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-subscription-manager/format-problems/#post-27862</guid>
                        <link>https://gvectors.com/forum/wpdiscuz-subscription-manager/format-problems/#post-27850</link>
                        <pubDate>Mon, 29 Mar 2021 14:33:57 +0000</pubDate>
                        <description><![CDATA[and by mobile (iPhone 8plus) you can see there is a format-problem too]]></description>
                        <content:encoded><![CDATA[<p>and by mobile (iPhone 8plus) you can see there is a format-problem too</p>
5317
<p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-subscription-manager/format-problems/#post-27850</guid>
                        <link>https://gvectors.com/forum/wpdiscuz-subscription-manager/format-problems/#post-27849</link>
                        <pubDate>Mon, 29 Mar 2021 14:29:10 +0000</pubDate>
                        <description><![CDATA[@astghik great. but pls look at the URL via incognito modus because there is a nginx cache active and without incongito you will not see the actual sit]]></description>
                        <content:encoded><![CDATA[@astghik great. but pls look at the URL via incognito modus because there is a nginx cache active and without incongito you will not see the actual site<br /><br />https://www.hello-world.net/pilgerausweis-jakobsweg/]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-subscription-manager/format-problems/#post-27849</guid>
                        <link>https://gvectors.com/forum/wpdiscuz-subscription-manager/format-problems/#post-27847</link>
                        <pubDate>Mon, 29 Mar 2021 14:26:26 +0000</pubDate>
This is just a small CSS conflict with the theme or other plugins. Please leave some example URL to allow us to debug the issue and provide some solution for you.]]></description>
                        <content:encoded><![CDATA[<p><span>@nick776,</span></p>
<p>This is just a small CSS conflict with the theme or other plugins. Please leave some example URL to allow us to debug the issue and provide some solution for you.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-subscription-manager/format-problems/#post-27847</guid>
                        <title>Format Problems</title>
                        <link>https://gvectors.com/forum/wpdiscuz-subscription-manager/format-problems/#post-27845</link>
                        <pubDate>Mon, 29 Mar 2021 14:22:25 +0000</pubDate>
                        <description><![CDATA[Hi There,
as you can see at the screenshot we have a tiny problem with the checkbox which is not left-aligned.
thnx for helping in advance
Nico]]></description>
                        <content:encoded><![CDATA[<p>Hi There,</p>
<p>as you can see at the screenshot we have a tiny problem with the checkbox which is not left-aligned.</p>
<p>thnx for helping in advance</p>
<p>Nico</p>
5316
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-subscription-manager/format-problems/#post-27845</guid>
