									WPDiscuz Frontend Moderation and Defender Pro - wpDiscuz Frontend Moderation				            </title>
            <link>https://gvectors.com/forum/wpdiscuz-frontend-moderation/wpdiscuz-frontend-moderation-and-defender-pro/</link>
            <lastBuildDate>Fri, 14 Aug 2026 10:12:47 +0000</lastBuildDate>
                        <title>RE: WPDiscuz Frontend Moderation and Defender Pro</title>
                        <link>https://gvectors.com/forum/wpdiscuz-frontend-moderation/wpdiscuz-frontend-moderation-and-defender-pro/paged/2/#post-20566</link>
                        <pubDate>Mon, 24 Feb 2020 12:58:13 +0000</pubDate>
                        <description><![CDATA[@johannes,
The developers one more time checked the issue and saw that the issue is caused by Defender Pro plugin. Please see the recorded video below:
The error message:
&lt;br&gt;&lt;b&amp;...]]></description>
                        <content:encoded><![CDATA[<p>@johannes,</p>
<p>The developers one more time checked the issue and saw that the issue is caused by Defender Pro plugin. Please see the recorded video below:</p>
<p><a href="https://www.screencast.com/t/ACB909s2">https://www.screencast.com/t/ACB909s2</a></p>
<p>The error message:</p>
<pre><span>&lt;br&gt;&lt;b&gt;Uncaught Error&lt;/b&gt;: Call to a member function to_array() on null in &lt;b&gt;/var/web/site/public_html/wp-content/plugins/<span style="color: #000080"><em><strong>wp-defender</strong></em></span>/app/module/audit/component/comment-audit.php&lt;/b&gt; on line &lt;b&gt;155&lt;/b&gt;&lt;br&gt;&lt;ul&gt;&lt;li&gt;processGenericComment()&lt;/li&gt;&lt;li&gt;invokeArgs()&lt;br&gt;&lt;span class="qm-info qm-supplemental"&gt;wp-content/plugins/wp-defender/app/module/audit/event-abstract.php:253&lt;/span&gt;&lt;/li&gt;&lt;li&gt;build_log_data()&lt;br&gt;&lt;span class="qm-info qm-supplemental"&gt;wp-content/plugins/wp-defender/app/module/audit/component/audit-api.php:360&lt;/span&gt;&lt;/li&gt;&lt;li&gt;WP_Defender\M\A\C\{closure}()&lt;br&gt;&lt;span class="qm-info qm-supplemental"&gt;wp-includes/class-wp-hook.php:290&lt;/span&gt;&lt;/li&gt;&lt;li&gt;apply_filters()&lt;br&gt;&lt;span class="qm-info qm-supplemental"&gt;wp-includes/class-wp-hook.php:312&lt;/span&gt;&lt;/li&gt;&lt;li&gt;do_action()&lt;br&gt;&lt;span class="qm-info qm-supplemental"&gt;wp-includes/plugin.php:478&lt;/span&gt;&lt;/li&gt;&lt;li&gt;do_action()&lt;br&gt;&lt;span class="qm-info qm-supplemental"&gt;wp-includes/comment.php:1429&lt;/span&gt;&lt;/li&gt;&lt;li&gt;wp_delete_comment()&lt;br&gt;&lt;span class="qm-info qm-supplemental"&gt;wp-content/plugins/wpdiscuz-frontend-moderation/class.wpDiscuzFrontEndModeration.php:403&lt;/span&gt;&lt;/li&gt;&lt;li&gt;deleteComment()&lt;br&gt;&lt;span class="qm-info qm-supplemental"&gt;wp-includes/class-wp-hook.php:288&lt;/span&gt;&lt;/li&gt;&lt;li&gt;apply_filters()&lt;br&gt;&lt;span class="qm-info qm-supplemental"&gt;wp-includes/class-wp-hook.php:312&lt;/span&gt;&lt;/li&gt;&lt;li&gt;do_action()&lt;br&gt;&lt;span class="qm-info qm-supplemental"&gt;wp-includes/plugin.php:478&lt;/span&gt;&lt;/li&gt;&lt;li&gt;do_action()&lt;br&gt;&lt;span class="qm-info qm-supplemental"&gt;wp-admin/admin-ajax.php:175&lt;/span&gt;&lt;/li&gt;&lt;/ul&gt;&lt;p&gt;Es gab einen kritischen Fehler auf deiner Website.&lt;/p&gt;&lt;p&gt;&lt;a href="</span><a class="c-link" href="https://slack-redir.net/link?url=https%3A%2F%2Fwordpress.org%2Fsupport%2Farticle%2Fdebugging-in-wordpress%2F" target="_blank" rel="noopener noreferrer">https://wordpress.org/support/article/debugging-in-wordpress/</a><span>"&gt;Erfahre mehr über die Fehlerbehebung in WordPress.&lt;/a&gt;&lt;/p&gt;</span></pre>
<p><span>Even if you deactivate the wpDiscuz plugin, each time when you try to delete the comments from the backend the issue still exists.</span></p>
<p> </p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/wpdiscuz-frontend-moderation/">wpDiscuz Frontend Moderation</category>                        <dc:creator>Elvina</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-frontend-moderation/wpdiscuz-frontend-moderation-and-defender-pro/paged/2/#post-20566</guid>
                        <link>https://gvectors.com/forum/wpdiscuz-frontend-moderation/wpdiscuz-frontend-moderation-and-defender-pro/paged/2/#post-20565</link>
                        <pubDate>Mon, 24 Feb 2020 11:27:48 +0000</pubDate>
                        <description><![CDATA[Hello,
I talked with the developer and they did thorough testing of any compatibility issues. They say the problem is caused by the frontend moderation plugin. 
So I would ask you to have ...]]></description>
                        <content:encoded><![CDATA[<p>Hello,</p>
<p>I talked with the developer and they did thorough testing of any compatibility issues. They say the problem is caused by the frontend moderation plugin. </p>
<p>So I would ask you to have another closer look at the problem, maybe you can find the issue.</p>
<p>Best wishes</p>
<p>Johannes</p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/wpdiscuz-frontend-moderation/">wpDiscuz Frontend Moderation</category>                        <dc:creator>Johannes</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-frontend-moderation/wpdiscuz-frontend-moderation-and-defender-pro/paged/2/#post-20565</guid>
                        <link>https://gvectors.com/forum/wpdiscuz-frontend-moderation/wpdiscuz-frontend-moderation-and-defender-pro/paged/2/#post-20476</link>
                        <pubDate>Thu, 20 Feb 2020 08:32:28 +0000</pubDate>
To find the reason of the issue the developers will need to modify the wpDiscuz Frontend Moderation add-on files. Please read this article to learn more about plugin editing feat...]]></description>
                        <content:encoded><![CDATA[<p><span>@johannes,</span></p>
<p><span>To find the reason of the issue the developers will need to modify the wpDiscuz Frontend Moderation add-on files. Please read this article to learn more about plugin editing feature: https://www.webhuntinfotech.com/enable-theme-plugin-editor-wordpress/</span></p>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-frontend-moderation/wpdiscuz-frontend-moderation-and-defender-pro/paged/2/#post-20476</guid>
                        <link>https://gvectors.com/forum/wpdiscuz-frontend-moderation/wpdiscuz-frontend-moderation-and-defender-pro/paged/2/#post-20459</link>
                        <pubDate>Wed, 19 Feb 2020 12:52:36 +0000</pubDate>
The issue is caused by the Defender Pro plugin.
It will be better if you contact the Defender Pro plugin support and ask them that question.
&nbsp;]]></description>
<p><span>The issue is caused by the Defender Pro plugin.</span></p>
<p><span>It will be better if you contact the <a href="https://wordpress.org/plugins/defender-security/" target="true">Defender Pro plugin </a>support and ask them that question.</span></p>
<p>&nbsp;</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-frontend-moderation/wpdiscuz-frontend-moderation-and-defender-pro/paged/2/#post-20459</guid>
                        <link>https://gvectors.com/forum/wpdiscuz-frontend-moderation/wpdiscuz-frontend-moderation-and-defender-pro/paged/2/#post-20457</link>
                        <pubDate>Wed, 19 Feb 2020 12:42:42 +0000</pubDate>
What do you mean by that?]]></description>
<p>What do you mean by that?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-frontend-moderation/wpdiscuz-frontend-moderation-and-defender-pro/paged/2/#post-20457</guid>
                        <link>https://gvectors.com/forum/wpdiscuz-frontend-moderation/wpdiscuz-frontend-moderation-and-defender-pro/#post-20456</link>
                        <pubDate>Wed, 19 Feb 2020 12:42:04 +0000</pubDate>
Could you please open a plugin editing feature to allow us to check it.
<p>Could you please open a plugin editing feature to allow us to check it.</p>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-frontend-moderation/wpdiscuz-frontend-moderation-and-defender-pro/#post-20456</guid>
                        <link>https://gvectors.com/forum/wpdiscuz-frontend-moderation/wpdiscuz-frontend-moderation-and-defender-pro/#post-20441</link>
                        <pubDate>Wed, 19 Feb 2020 10:02:47 +0000</pubDate>
                        <description><![CDATA[Hello and thanks for your answer,
I am afraid the issue is still there for me.
Best
Johannes]]></description>
                        <content:encoded><![CDATA[<p>Hello and thanks for your answer,</p>
<p>I am afraid the issue is still there for me.</p>
<p>Best</p>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-frontend-moderation/wpdiscuz-frontend-moderation-and-defender-pro/#post-20441</guid>
                        <link>https://gvectors.com/forum/wpdiscuz-frontend-moderation/wpdiscuz-frontend-moderation-and-defender-pro/#post-20433</link>
                        <pubDate>Wed, 19 Feb 2020 08:45:42 +0000</pubDate>
                        <description><![CDATA[Hi @johannes,
This will be fixed in the next version update.
In case if you want to fix it as soon as possible please follows the steps below to get it resolved:
1. Open the /wp-content/p...]]></description>
                        <content:encoded><![CDATA[<p>Hi <span>@johannes,</span></p>
<p>This will be fixed in the next version update.</p>
<p>In case if you want to fix it as soon as possible p<span>lease follows the steps below to get it resolved:</span></p>
<p>1. Open the<span> </span><span style="color: #000080"><em><strong>/wp-content/plugins/wpdiscuz/class.WpdiscuzCore.php</strong></em></span><span> </span>file</p>
<p>2. Find the following line (1068 line):</p>
<pre>wp_register_script('wpdiscuz-jquery-cookie', plugins_url(WPDISCUZ_DIR_NAME . '/assets/third-party/wpdcookiejs/customcookie.js'), array('jquery'), $this-&gt;version, true);</pre>
<p>3. Replace with the following one:</p>
<pre>wp_register_script('wpdiscuz-jquery-cookie', plugins_url(WPDISCUZ_DIR_NAME . '/assets/third-party/wpdccjs/wpdcc.js'), array('jquery'), $this-&gt;version, true);</pre>
<p>Don't forget to delete all caches and press CTRL+F5(twice) on the frontend before checking.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-frontend-moderation/wpdiscuz-frontend-moderation-and-defender-pro/#post-20433</guid>
                        <link>https://gvectors.com/forum/wpdiscuz-frontend-moderation/wpdiscuz-frontend-moderation-and-defender-pro/#post-20397</link>
                        <pubDate>Tue, 18 Feb 2020 07:35:59 +0000</pubDate>
Please send it&nbsp;as a PM message.
<p><span>Please send it&nbsp;</span><span>as a PM message.</span></p>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-frontend-moderation/wpdiscuz-frontend-moderation-and-defender-pro/#post-20397</guid>
                        <link>https://gvectors.com/forum/wpdiscuz-frontend-moderation/wpdiscuz-frontend-moderation-and-defender-pro/#post-20385</link>
                        <pubDate>Mon, 17 Feb 2020 15:19:13 +0000</pubDate>
                        <description><![CDATA[The site is not live yet. Can I send you the credentials somewhere?]]></description>
                        <content:encoded><![CDATA[<p>The site is not live yet. Can I send you the credentials somewhere?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-frontend-moderation/wpdiscuz-frontend-moderation-and-defender-pro/#post-20385</guid>
