									Call to undefined method wpdFormAttr\Form::getFormCustomFields() - wpDiscuz Comment Search				            </title>
            <link>https://gvectors.com/forum/wpdiscuz-comment-search/call-to-undefined-method-wpdformattrformgetformcustomfields/</link>
            <lastBuildDate>Wed, 20 May 2026 20:22:05 +0000</lastBuildDate>
                        <title>RE: Call to undefined method wpdFormAttr\Form::getFormCustomFields()</title>
                        <link>https://gvectors.com/forum/wpdiscuz-comment-search/call-to-undefined-method-wpdformattrformgetformcustomfields/paged/2/#post-8478</link>
                        <pubDate>Thu, 26 Apr 2018 20:13:15 +0000</pubDate>
                        <description><![CDATA[This fixed the issue. Thank you very much! This thread can be closed.]]></description>
                        <content:encoded><![CDATA[<p>This fixed the issue. Thank you very much! This thread can be closed.</p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/wpdiscuz-comment-search/">wpDiscuz Comment Search</category>                        <dc:creator>HenriMatthijssen</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-comment-search/call-to-undefined-method-wpdformattrformgetformcustomfields/paged/2/#post-8478</guid>
                        <link>https://gvectors.com/forum/wpdiscuz-comment-search/call-to-undefined-method-wpdformattrformgetformcustomfields/paged/2/#post-8475</link>
                        <pubDate>Thu, 26 Apr 2018 19:55:57 +0000</pubDate>
                        <description><![CDATA[Dear @henrimatthijssen,Custom fields is that you create in your &quot;Default form&quot; in Dashboard &gt; Comments &gt; Form admin page. e.g. new Rating field.More info heresuggest you the following ...]]></description>
                        <content:encoded><![CDATA[<p>Dear @henrimatthijssen,</p><p>Custom fields is that you create in your "Default form" in Dashboard &gt; Comments &gt; Form admin page. </p><p>e.g. new Rating field.</p><p>2023</p><p>More info here:</p><p>https://wpdiscuz.com/docs/wpdiscuz-documentation/comment-forms/</p><p>I suggest you the following temporary solution.</p><p>1. In wpDiscuz &gt; forms &gt; wpdFormAttr &gt; Form.php file find this line</p><pre> public function setFormID($formID) {</pre><p>2024</p><p>2. Add the following code <span style="color: #ff0000"><strong>above</strong> </span>it</p><pre>public function getFormCustomFields () {<br />       return $this-&gt;formCustomFields;<br /> }</pre><p>2025</p><p>This will be fixed in next version release.</p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/wpdiscuz-comment-search/">wpDiscuz Comment Search</category>                        <dc:creator>Astghik</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-comment-search/call-to-undefined-method-wpdformattrformgetformcustomfields/paged/2/#post-8475</guid>
                        <link>https://gvectors.com/forum/wpdiscuz-comment-search/call-to-undefined-method-wpdformattrformgetformcustomfields/paged/2/#post-8473</link>
                        <pubDate>Thu, 26 Apr 2018 19:33:02 +0000</pubDate>
                        <description><![CDATA[Workaround for avoiding this issue is now:Select only &#039;Content&#039;, &#039;Author&#039; and &#039;Email&#039; as &quot;Available search fields&quot; and use &#039;Content&#039; as &quot;Default search field&quot;.However I would prefer to have ...]]></description>
                        <content:encoded><![CDATA[<p>Workaround for avoiding this issue is now:</p><p>Select only 'Content', 'Author' and 'Email' as "Available search fields" and use 'Content' as "Default search field".</p><p>However I would prefer to have "Default search field" for 'All' which is with this workaround not possible.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-comment-search/call-to-undefined-method-wpdformattrformgetformcustomfields/paged/2/#post-8473</guid>
                        <link>https://gvectors.com/forum/wpdiscuz-comment-search/call-to-undefined-method-wpdformattrformgetformcustomfields/paged/2/#post-8471</link>
                        <pubDate>Thu, 26 Apr 2018 19:10:02 +0000</pubDate>
                        <description><![CDATA[Can you first explain what &#039;Custom Fields&#039; means and how to configure it? I have the feeling this is the culprit as I do not use/have it?Update: I am pretty sure it is related to &#039;Custom Fie...]]></description>
                        <content:encoded><![CDATA[<p>Can you first explain what 'Custom Fields' means and how to configure it? I have the feeling this is the culprit as I do not use/have it?</p><p><strong>Update:</strong> I am pretty sure it is related to 'Custom Fields'. Only when I use as search 'All' or 'Custom Fields' I get this error-message.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-comment-search/call-to-undefined-method-wpdformattrformgetformcustomfields/paged/2/#post-8471</guid>
                        <link>https://gvectors.com/forum/wpdiscuz-comment-search/call-to-undefined-method-wpdformattrformgetformcustomfields/paged/2/#post-8470</link>
                        <pubDate>Thu, 26 Apr 2018 19:02:46 +0000</pubDate>
                        <description><![CDATA[I&#039;m sorry but there is no way to help you without having admin access. Could you please send admin login details to supportgvectors.com email address?]]></description>
                        <content:encoded><![CDATA[<p>I'm sorry but there is no way to help you without having admin access. Could you please send admin login details to supportgvectors.com email address?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-comment-search/call-to-undefined-method-wpdformattrformgetformcustomfields/paged/2/#post-8470</guid>
                        <link>https://gvectors.com/forum/wpdiscuz-comment-search/call-to-undefined-method-wpdformattrformgetformcustomfields/#post-8469</link>
                        <pubDate>Thu, 26 Apr 2018 18:54:31 +0000</pubDate>
                        <description><![CDATA[1. No I still have the same error. It seems only happening when using &#039;All&#039;. Is this related to &#039;Custom Fields&#039; which I have de-selected. Can you further explain what &#039;Custom Fields&#039; means a...]]></description>
                        <content:encoded><![CDATA[<p>1. No I still have the same error. It seems only happening when using 'All'. Is this related to 'Custom Fields' which I have de-selected. Can you further explain what 'Custom Fields' means and how to configure it? See attached screenshot for the error: 2022</p><p>2. OK. Understood</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-comment-search/call-to-undefined-method-wpdformattrformgetformcustomfields/#post-8469</guid>
                        <link>https://gvectors.com/forum/wpdiscuz-comment-search/call-to-undefined-method-wpdformattrformgetformcustomfields/#post-8468</link>
                        <pubDate>Thu, 26 Apr 2018 18:42:37 +0000</pubDate>
                        <description><![CDATA[1.  Error thrownCall to undefined method wpdFormAttr\Form::getFormCustomFields()We need to know is this issue fixed?2. First indication that it is wrong is already that despite I have enable...]]></description>
                        <content:encoded><![CDATA[<p>1. </p><blockquote><p> Error thrown<br />Call to undefined method wpdFormAttr\Form::getFormCustomFields()</p></blockquote><p>We need to know is this issue fixed?</p><p>2. </p><blockquote><p>First indication that it is wrong is already that despite I have enabled in "Available search fields" the settings 'All', 'Content', 'Author' and 'Email' and as "Default search field" set 'All', that when I press the 'search settings' button on my blog I notice that initially only 'Content', 'Author' and 'Email' is shown in dropdown box. I would have expected the 'All' selection as well here.</p></blockquote><p>This is the addon working logic. If you select one of these as value of  Default search field, it will not be shown  from frontend. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-comment-search/call-to-undefined-method-wpdformattrformgetformcustomfields/#post-8468</guid>
                        <link>https://gvectors.com/forum/wpdiscuz-comment-search/call-to-undefined-method-wpdformattrformgetformcustomfields/#post-8467</link>
                        <pubDate>Thu, 26 Apr 2018 18:21:48 +0000</pubDate>
                        <description><![CDATA[I tried that &#039;reset options&#039; (lost all my translations, color settings, etc). Further I deleted my Supercache, Pagespeed cache and all caches of my web-browsers with CCleaner, but I am still...]]></description>
                        <content:encoded><![CDATA[<p>I tried that 'reset options' (lost all my translations, color settings, etc). Further I deleted my Supercache, Pagespeed cache and all caches of my web-browsers with CCleaner, but I am still getting the same results as above.</p><p>First indication that it is wrong is already that despite I have enabled in "Available search fields" the settings 'All', 'Content', 'Author' and 'Email' and as "Default search field" set 'All', that when I press the 'search settings' button on my blog I notice that initially only 'Content', 'Author' and 'Email' is shown in dropdown box. I would have expected the 'All' selection as well here.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-comment-search/call-to-undefined-method-wpdformattrformgetformcustomfields/#post-8467</guid>
                        <link>https://gvectors.com/forum/wpdiscuz-comment-search/call-to-undefined-method-wpdformattrformgetformcustomfields/#post-8465</link>
                        <pubDate>Thu, 26 Apr 2018 17:01:56 +0000</pubDate>
                        <description><![CDATA[Hi HenriMatthijssen,Please navigate to Dashboard &gt; Comments &gt; Settings &gt; Addons &gt; Comment Search admin page, click on &quot;Reset Options&quot; button. Then delete all caches and check it ...]]></description>
                        <content:encoded><![CDATA[<p>Hi HenriMatthijssen,</p><p>Please navigate to Dashboard &gt; Comments &gt; Settings &gt; Addons &gt; Comment Search admin page, click on "Reset Options" button. </p><p>2021</p><p>Then delete all caches and check it again. </p><p> </p><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-comment-search/call-to-undefined-method-wpdformattrformgetformcustomfields/#post-8465</guid>
                        <title>Call to undefined method wpdFormAttr\Form::getFormCustomFields()</title>
                        <link>https://gvectors.com/forum/wpdiscuz-comment-search/call-to-undefined-method-wpdformattrformgetformcustomfields/#post-8464</link>
                        <pubDate>Thu, 26 Apr 2018 15:45:55 +0000</pubDate>
                        <description><![CDATA[wpDiscuz Comment Search Versie: 1.1.9 on latest WordPress 4.9.5 with Avada Theme 5.5In &quot;Available search fields&quot; I have seleced &#039;All&#039;, &#039;Content&#039;, &#039;Author&#039; and &#039;Email&#039;. Further I have set &quot;De...]]></description>
                        <content:encoded><![CDATA[<p>wpDiscuz Comment Search Versie: 1.1.9 on latest WordPress 4.9.5 with Avada Theme 5.5</p><p>In "Available search fields" I have seleced 'All', 'Content', 'Author' and 'Email'. Further I have set "Default search field" to 'All'.</p><p>When I press the 'search settings' button I notice that initially only 'Content', 'Author' and 'Email' is shown. I would have expected the 'All' selection as well.</p><p>When I search for a phrase I get an error:</p><p>Error thrown<br />Call to undefined method wpdFormAttr\Form::getFormCustomFields()</p><p>When I select in 'search settings' explicitly a field it works again. However funny enough when I check the 'search settings' after this it displays different content ('All', 'Author' and 'Email').</p><p>I have the feeling you have a bug in your code for populating the 'search settings'.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-comment-search/call-to-undefined-method-wpdformattrformgetformcustomfields/#post-8464</guid>
