									Report and flagging issue - wpDiscuz Comment Report &amp; Flagging				            </title>
            <link>https://gvectors.com/forum/wpdiscuz-comment-report-flagging/report-and-flagging-issue/</link>
            <lastBuildDate>Wed, 14 Oct 2026 04:42:38 +0000</lastBuildDate>
                        <title>RE: Report and flagging issue</title>
                        <link>https://gvectors.com/forum/wpdiscuz-comment-report-flagging/report-and-flagging-issue/#post-27400</link>
                        <pubDate>Mon, 01 Mar 2021 12:16:51 +0000</pubDate>
                        <description><![CDATA[@selfca115,
If the two options mentioned below are enabled then it automatically sends the email notification to the Admin Email, thus those comments are not being held for moderation. 
...]]></description>
                        <content:encoded><![CDATA[<p><span>@selfca115,</span></p>
<p>If the two options mentioned below are enabled then it automatically sends the email notification to the Admin Email, thus those comments are not being held for moderation. </p>
<ul>
<li>Enable comment reporting pop-up form for registered users</li>
<li>Enable comment reporting pop-up form for guests</li>
</ul>
<p>If you disable those options the moderation feature will work fine. </p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/wpdiscuz-comment-report-flagging/">wpDiscuz Comment Report &amp; Flagging</category>                        <dc:creator>Astghik</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-comment-report-flagging/report-and-flagging-issue/#post-27400</guid>
                        <link>https://gvectors.com/forum/wpdiscuz-comment-report-flagging/report-and-flagging-issue/#post-27391</link>
                        <pubDate>Mon, 01 Mar 2021 10:46:25 +0000</pubDate>
We&#039;ll check and back to you asap.]]></description>
<p>We'll check and back to you asap. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-comment-report-flagging/report-and-flagging-issue/#post-27391</guid>
                        <title>Report and flagging issue</title>
                        <link>https://gvectors.com/forum/wpdiscuz-comment-report-flagging/report-and-flagging-issue/#post-27385</link>
                        <pubDate>Mon, 01 Mar 2021 10:22:13 +0000</pubDate>
                        <description><![CDATA[i have set
&quot; Do auto-moderation if comment is flagged more than &quot; to 4 and made 5 times comments to flagged with different user login but that comment has not unapproved...what could be the...]]></description>
                        <content:encoded><![CDATA[<p>i have set</p>
<div class="wpd-opt-name"><label for="flagCount">" Do auto-moderation if comment is flagged more than " to 4 and made 5 times comments to flagged with different user login but that comment has not unapproved...what could be the issue?</label></div>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/wpdiscuz-comment-report-flagging/">wpDiscuz Comment Report &amp; Flagging</category>                        <dc:creator>selfca115</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-comment-report-flagging/report-and-flagging-issue/#post-27385</guid>
