									Not saving custom post type - wpDiscuz				            </title>
            <link>https://gvectors.com/forum/wpdiscuz-comment-plugin-support/not-saving-custom-post-type/</link>
            <lastBuildDate>Thu, 21 May 2026 17:50:13 +0000</lastBuildDate>
                        <title>RE: Not saving custom post type</title>
                        <link>https://gvectors.com/forum/wpdiscuz-comment-plugin-support/not-saving-custom-post-type/#post-22651</link>
                        <pubDate>Fri, 01 May 2020 19:33:48 +0000</pubDate>
                        <description><![CDATA[@elvina
Okk. Thanks a lot]]></description>
                        <content:encoded><![CDATA[<p>@elvina</p>
<p>Okk. Thanks a lot</p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/wpdiscuz-comment-plugin-support/">wpDiscuz</category>                        <dc:creator>Civil Engineering Notes</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-comment-plugin-support/not-saving-custom-post-type/#post-22651</guid>
                        <link>https://gvectors.com/forum/wpdiscuz-comment-plugin-support/not-saving-custom-post-type/#post-22649</link>
                        <pubDate>Fri, 01 May 2020 18:31:52 +0000</pubDate>
                        <description><![CDATA[@civilenggnotes,
The issue is solved by our developers.]]></description>
                        <content:encoded><![CDATA[<p>@civilenggnotes,</p>
<p>The issue is solved by our developers.</p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/wpdiscuz-comment-plugin-support/">wpDiscuz</category>                        <dc:creator>Elvina</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-comment-plugin-support/not-saving-custom-post-type/#post-22649</guid>
                        <link>https://gvectors.com/forum/wpdiscuz-comment-plugin-support/not-saving-custom-post-type/#post-22614</link>
                        <pubDate>Fri, 01 May 2020 10:07:47 +0000</pubDate>
I have already enabled that. It may be due to caching issue. I am purging all. Hope you will be able to edit this time. And i still could not remember any other star rating option t...]]></description>
<p>I have already enabled that. It may be due to caching issue. I am purging all. Hope you will be able to edit this time. And i still could not remember any other star rating option to use in your comment system. But i am checking again. And if you are talking about "<strong>Rate my Post - WP Rating System" </strong>plugin, it is not affecting the commenting system..</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-comment-plugin-support/not-saving-custom-post-type/#post-22614</guid>
                        <link>https://gvectors.com/forum/wpdiscuz-comment-plugin-support/not-saving-custom-post-type/#post-22613</link>
                        <pubDate>Fri, 01 May 2020 09:55:23 +0000</pubDate>
I am enabling file editing option.
Please make sure that you are enabled the plugin editing, because of developers still not able to edit/deactivate and activate the p...]]></description>
<blockquote>
<p><span>I am enabling file editing option.</span></p>
</blockquote>
<p>Please make sure that you are enabled the plugin editing, because of developers still not able to edit/deactivate and activate the plugin.</p>
<blockquote>
<p><span>And i did not understand which star rating you are talking about. Rating on comment from your plugin is disabled. And post rating from other plugin is placed above comment form.</span></p>
</blockquote>
<p>When we edit the default wpDiscuz form from the dashboard, in the form page display the setting of the rating plugin you use. So if it's possible please don't display it on our comment form page.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-comment-plugin-support/not-saving-custom-post-type/#post-22613</guid>
                        <link>https://gvectors.com/forum/wpdiscuz-comment-plugin-support/not-saving-custom-post-type/#post-22610</link>
                        <pubDate>Fri, 01 May 2020 08:59:04 +0000</pubDate>
Okk. I am enabling file editing option. And i did not understand which star rating you are talking about. Rating on comment from your plugin is disabled. And post rating from other ...]]></description>
<p>Okk. I am enabling file editing option. And i did not understand which star rating you are talking about. Rating on comment from your plugin is disabled. And post rating from other plugin is placed above comment form.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-comment-plugin-support/not-saving-custom-post-type/#post-22610</guid>
                        <link>https://gvectors.com/forum/wpdiscuz-comment-plugin-support/not-saving-custom-post-type/#post-22607</link>
                        <pubDate>Fri, 01 May 2020 08:37:27 +0000</pubDate>
Please open a plugin editing feature. Currently, the developers are not able to edit/deactivate and activate the plugin.
If it&#039;s possible, please don&#039;t display the rating ...]]></description>
<p><span>Please open a plugin editing feature. Currently, the developers are not able to edit/deactivate and activate the plugin.</span></p>
<p>If it's possible, please don't display the rating box under our comment form.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-comment-plugin-support/not-saving-custom-post-type/#post-22607</guid>
                        <link>https://gvectors.com/forum/wpdiscuz-comment-plugin-support/not-saving-custom-post-type/#post-22594</link>
                        <pubDate>Thu, 30 Apr 2020 16:24:20 +0000</pubDate>
                        <description><![CDATA[hello @astghik
I have sent you the details in that mail, but have not heard any responses till now, please let me know what happened??]]></description>
                        <content:encoded><![CDATA[<p>hello <span>@astghik</span></p>
<p>I have sent you the details in that mail, but have not heard any responses till now, please let me know what happened??</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-comment-plugin-support/not-saving-custom-post-type/#post-22594</guid>
                        <link>https://gvectors.com/forum/wpdiscuz-comment-plugin-support/not-saving-custom-post-type/#post-22497</link>
                        <pubDate>Tue, 28 Apr 2020 10:40:15 +0000</pubDate>
                        <description><![CDATA[Hi@civilenggnotes,
Please send the admin login details to infogvectors.com email address I&#039;ll ask the developers to check the issue for you.]]></description>
                        <content:encoded><![CDATA[<p>Hi<span>@civilenggnotes,</span></p>
<p>Please send the admin login details to infogvectors.com email address I'll ask the developers to check the issue for you. </p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/wpdiscuz-comment-plugin-support/">wpDiscuz</category>                        <dc:creator>Astghik</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-comment-plugin-support/not-saving-custom-post-type/#post-22497</guid>
                        <title>Not saving custom post type</title>
                        <link>https://gvectors.com/forum/wpdiscuz-comment-plugin-support/not-saving-custom-post-type/#post-22484</link>
                        <pubDate>Mon, 27 Apr 2020 21:21:48 +0000</pubDate>
                        <description><![CDATA[Hi..
I have installed quiz and survey master plugin to enable a quiz section in my blog. I want to show wpdiscuz comment form the quiz page. So i was trying to save the qsm_quiz type post f...]]></description>
                        <content:encoded><![CDATA[<p>Hi..</p>
<p>I have installed quiz and survey master plugin to enable a quiz section in my blog. I want to show wpdiscuz comment form the quiz page. So i was trying to save the qsm_quiz type post from comment&gt;Form&gt;Default form. But the save button is not working. So i am not able to save the change. I tried from mobile and computer both. Is it due some plugin problem, or it is from my end?? Or is there any other way to do that??</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-comment-plugin-support/not-saving-custom-post-type/#post-22484</guid>
